[Mapbender_dev] Re: [Mapbender] #871: WFS-Search: Use actual SRS from mapframe/changeEPSG
Mapbender mapbender_dev at lists.osgeo.org
Wed May 23 01:57:05 EDT 2012
  Reporter:  frankjaeger  |       Owner:  dev
      Type:  enhancement  |      Status:  reopened
  Priority:  major        |   Milestone:  2.7.3 release
 Component:  wfs          |     Version:  2.7.1
Resolution:               |    Keywords:  WFS-Search,SRS,EPSG,changeEPSG
Changes (by armin11):
  * status:  closed => reopened
  * resolution:  worksforme =>
Comment:
 Replying to [comment:2 verenadiewald]:
 > current gui srs is used for WFS getFeature request, so Mapbender reacts
 correct -> you have to ensure your wfs can deal with parameter srsName for
 on-the-fly-transformation
 The parameter srsName will only be handled up from wfs 1.1.0. The list of
 supported srs for a wfs was not handled by mapbender til 2 weeks ago.
 Maybe mapbenders gazetteer module don't react on this? Have to be tested.
 In trunk, there is now a handling of different srs for each featuretype.
 It is mangaged in the database on loadWFS and updateWFS. Also the
 latlonBboxes for each featuretype are managed since 2 weeks. This is
 needed to fullfil the INSPIRE demands for Download Services and to
 generate the metadata elements!
 Please test if a srs from the featuretype_epsg table is added to the WFS
 getfeature request in case of WFS 1.1.0.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/871#comment:3>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
