[Mapbender_dev] [Mapbender-users] GUIs are loading very slowly in Mapbender v2.7.2
Marc Manns marcmanns at gmx.de
Wed Oct 24 10:19:25 PDT 2012
today i added this sollution to my installation too.
Now the loading-process is so much faster (again) :-) .
thank you.
regards Marc
Am 24.10.2012 13:45, schrieb Astrid Emde:
> Hello Verena, hello all,
> Verena - I added your changes to a running Mapbender applications with lot
> of WMS and I have significant faster loading of my application.
> So thank you for this solution. All Mapbender applications that handle lot
> of WMS/layers and are loading very slow should implement the changes.
> Also we should provide it in the next Mapbender version 2.7.4.
> I saw that you created the cache directory already.
> I would suggest to add the mapframe1 element variable loadFromCache to
> every application and set the default to 0.
> We have to add the SQL to the update-Script.
> http://trac.osgeo.org/mapbender/browser/branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
> We should move your documentation from the mail to the wiki (or js-docu).
> I added some information to the wiki page already:
> http://www.mapbender.org/Mapframe
> Best regards Astrid
> On Mon, October 15, 2012 9:45 am, Verena Diewald wrote:
>> Hello list,
>> please try our workaround solution for a faster loading mechanism. What
>> did we do: We created a kind of cache mechanism which stores the initial
>> js mapobject produced by the WMC loading process. The cache file is being
>> created loading the gui for the first time. As soon as it exists, the
>> gui's mapobject is loaded from the cache file, not again from the WMC
>> process. This makes the loading process faster. Changing the mapobject of
>> the gui (adding WMS, deleting WMS, updating WMS...) deletes the cache file
>> and the gui has to be loaded the slowly way once again for creating a new
>> cache file. Use of the cache file loading process can be controlled using
>> the element var "loadFromCache" of the mapframe1 gui element. This
>> workaround should at least be suitable for all mapbender guis which are
>> not ever-changing (e.g. portal guis). If you want to use the newer GET
>> params api [1] you can not use this woraround. If you want to use the older
>> GET params (e.g. mb_myBBOX, mb_myPOI2SCALE,
>> visiblelayers, querylayers...) you can do this with activated cache
>> solution. What you have to do for integration of the workaround:
>> 1) get all changed files from the Mapbender 2.7 SVN branch of changeset
>> 8491 [2]
>> 2) create a cache directory in the Mapbender's root directory
>> (mapbender/cache) and set the Apache user as owner of this directory
>> 3) add the element var "loadFromCache" to gui element mapframe1 and set
>> it to 1 if you want to use the cache mechanism: INSERT INTO
>> gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context,
>> var_type) VALUES('<gui_id>', 'mapframe1', 'loadFromCache', '1', 'define if
>> mapObj should be loaded from cache if cache file already exists'
>> ,'php_var');
>> Best regards,
>> Verena
>> [1] http://www.mapbender.org/GET-Parameter
>> [2] http://trac.osgeo.org/mapbender/changeset/8491
>> Am 22.08.2012 08:57, schrieb Verena Diewald:
>>> Hi list,
>>> we decided to start another analysis of the performance problem. Perhaps
>>> it is possible to do a preprocessing of the WMC loading mechanism. We
>>> will think about it. Further ideas are welcome.
>>> Best regards,
>>> Verena
>>> Am 16.08.2012 16:22, schrieb Verena Diewald:
>>>> Hallo Liste,
>>>> Am 16.08.2012 14:47, schrieb Armin Retterath:
>>>>> Hallo zusammen,
>>>>> es liegt leider nicht an der GUI. Wir müssen etwas am Grundprinzip
>>>>>   des Ladens anpassen. Seit der neuen Version dauert es einfach
>>>>> länger. Das aktuelle Verfahren ist bei verteilten Strukturen mit
>>>>> unterschiedlichen Nutzungsbedingungen leider notwendig und ist
>>>>> durch unsere Weiterentwicklung in den Jahren 2010/2011 dort
>>>>> reingeflossen. Ggf. könnte man optional einen schnelleren
>>>>> Ladevorgang realisieren.
>>>>> Ist aber ein bisschen Programmieraufwand ;-) . Wenn ich nach der
>>>>> Umsetzung der INSPIRE Anforderungen für Downloaddienste was Zeit
>>>>> bekomme, kann ich mich ja mal dransetzen. Problem liegt serverseitig
>>>>> im javascripts/initWmcObj.php Script begründet. Kann man debuggen
>>>>> und dann mal testen wie die Verarbeitungszeit ansteigt, wenn eine
>>>>> GUI immer mehr Dienste hinzubekommt :-( .
>>>> Ich habe mir vor einiger Zeit die Verarbeitungszeiten des WMC im
>>>> Zusammenhang mit ansteigender Anzahl an WMS in einer GUI angeschaut.
>>>> Es ist leider wirklich so, dass die Erstellung des initialen WMC pro
>>>> hinzukommendem WMS immer länger dauert und sich dadurch die Ladezeit
>>>> der GUI immer weiter erhöht.
>>>> Gruß,
>>>> Verena
>>>>> Grüße
>>>>> Armin
>>>>> On 16.08.2012 14:38, Thomas Baschetti wrote:
>>>>>> Am 16.08.2012 09:28, schrieb Sebastian Schwarz:
>>>>>>> Hallo Liste,
>>>>>>> wir haben ein Problem mit Mapbender v2.7.2: Die GUIs, die wir
>>>>>>> bislang umgesetzt haben, weisen durchweg sehr lange Ladezeiten
>>>>>>> auf, vorallem dann, wenn sie über zahlreiche eingebundene WMS
>>>>>>> verfügen. Über diesen Effekt haben wir bereits mit der
>>>>>>> WhereGroup gesprochen, die dazu
>>>>>>> folgende Auskunft gab: Beim Laden einer GUI muss das Skript in
>>>>>>> map.php warten, bis serverseitig aller WMS-Informationen zu
>>>>>>> einem initialen WMC verarbeitet sind, bevor das Skript in die
>>>>>>> eigentliche GUI springen und diese schließlich anzeigen kann.
>>>>>>> Dieses Laden dauert umso länger, je
>>>>>>> mehr WMS in die GUI eingebunden sind.
>>>>>> ja, das Laden kann mit komplexeren Anwendungen und vielen WMS
>>>>>> leider recht langwierig werden :-(
>>>>>>> Nun zur eigentlichen Frage: Gibt es eine Möglichkeit, diese
>>>>>>> Ladezeit
>>>>>>> bzw. das serverseitige Verarbeiten der WMS-Informationen zu
>>>>>>> einem initialen WMC zu verkürzen?
>>>>>> als Idee zum Testen: Habt ihr die GUI schon mal manuell als WMC
>>>>>> Dokument abgespeichert
>>>>>> (modul saveWMC),
>>>>>> und versucht die dann in eine schlanke&schnelle GUI zu laden? Geht
>>>>>>   das dann schnell? Falls ja kann man das sicherlich
>>>>>> automatisieren, aber falls auch das nicht schnell genug ist müsste
>>>>>> man versuchen die Verarbeitung des WMC generell zu
>>>>>> beschleunigen...
>>>>>> Mit freundlichen Grüßen
>>>>>> Thomas Baschetti
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_dev mailing list
