[Mapbender-dev] [Mapbender-users] Mapbender3 Version 3.0.6.0 released
Axel Schaefer axel.schaefer at wheregroup.com
Wed May 10 00:29:26 PDT 2017
Dear Mapbender-Users and Mapbender-Devs.
We had to exchange the download-files at:
http://mapbender3.org/builds/mapbender3-starter-3.0.6.0.zip
http://mapbender3.org/builds/mapbender3-starter-3.0.6.0.tar.gz
Our build-process left out the vendor/viscreation/vis-ui.js/src
directory, so the Digitizer interface could not build itself up.
The new zip/tar.gz files contain the files.
In this step we changed a bit of the structure at:
http://mapbender3.org/builds/ so that you find a bit easier what you're
looking for. :-)
Best regards
Axel and Andriy.
Am 05.05.2017 um 15:38 schrieb Axel Schaefer:
> Dear Mapbender Users and Mapbender Developers
> You'll find the German version of this announcement below.
> Dear Mapbender-User and Mapbender-Developers!
> Today we published version 3.0.6.0 of Mapbender3. Thanks to all participants!
> It's a Feature-Release with new functions and many bug fixes. We refer
> to the versions-log at the Mapbender3 documentation [1]
> (http://doc.mapbender3.org/de/book/versions.html), where we summarized
> the list by chapters. Many changes relate to the code base, which has
> been tidied in many parts.
> Download [2]: http://mapbender3.org/?q=de/download or directly via the
> link in footnote [3].
> - The TAR.GZ file is suitable for Linux systems geeignet, because it
>   uses symlinks in the web/bundles directory.
> - The ZIP file is for Windows (and Linux) and doesn't use symlinks,
>   because they are not supported by Windows.
> Source code [4]:https://github.com/mapbender/mapbender-starter
> Work and develop with the source code (Contributing.md) [5]:
> https://github.com/mapbender/mapbender-starter/blob/release/3.0.6/CONTRIBUTING.md
> (also in the master-branch)
> Report bugs [6]: https://github.com/mapbender/mapbender/issues
> Documentation [7]: http://doc.mapbender3.org/
> Installation and Update [8]:
> http://doc.mapbender3.org/en/book/installation.html
> Never worked with Mapbender3 before [9]?
> http://doc.mapbender3.org/en/book/quickstart.html
> Mapbender-demo [10]: https://demo.mapbender3.org/
> Sandbox with opportunity to register [11]:
> https://sandbox.mapbender3.org/
> New functions in this release, among other things, contain the Print,
> the Digitizer, the Measurement and the display of users for secured
> elements. We had to lift the system requirements to PHP 5.5.4 and say
> goodbye to PHP 5.3, which has completed its life cycle a long time
> ago. First we wanted to publish the release as bugfix-release, but
> changed this to a feature-release because of outsourcing the submodules
> (mapbender, fom, owsproy), among other things. Thus also the Digitizer
> is integrated as Version 1.1.
> We also created some things, which simplify the update of Mapbender and
> the implementation of new functions with modules in the
> future. Therefore you can find many references to the CONTRIBUTING.MD
> [4] in the developer part of the documentation on mapbender3.org
> [6]. The CONTRIBUTING.MD is a help file for developers and advanced
> users, which we put directly to the source-code of the Mapbender-Starter
> project. We want to achieve an easier entry into development for
> Mapbender. A typical developer is able to open and read this file
> directly in his coding-environment. He (or she) will see that Mapbender
> is easily set up and can be started directly with the Symfony integrated
> web-server. We will continue and update this Contributing.md. Thus the
> Mapbender-documentation will develop to a mere user documentation.
> What’s next? We created some structural basics to publish
> bugfix-versions more frequently. Our rule of thumb is about "2 handful
> of bugs" or 2 months time. We will document the bugs and fixes on the
> issue tracker on Github. Currently we are working on moving our public
> test server, to which we will refer – as far as possible – in our bug
> reports.
> Feature-versions will be published irregularly. Currently we are working
> on the 3.0.6 branch and maintain the 3.0.7 branch, in which the features
> will be integrated. The next feature-release will result from the code
> of the 3.0.7 branch with the bugfixes from the 3.0.6 branch. If you
> filter by versions, you can find the features in the issue-tracker
> [12]. There you can also find the 3.1 branch, which will come with
> bigger changes in the architecture (Symfony dependence and thus the
> directory structure) and from which we already were able to implement
> smaller parts in this release.
> Links/Footnotes:
> [1] Version history: http://doc.mapbender3.org/en/book/versions.html
> [2] Download: http://mapbender3.org/?q=en/download
> [3] Download of theBuilds: http://www.mapbender3.org/builds/
> [4] Download of the source code:
> [5] Contributing.md:
> [6] Feature and Bugtracker:
> [7] Mapbender-Documentation: http://doc.mapbender3.org/
> [8] Installation: http://doc.mapbender3.org/en/book/installation.html
> [9] Mapbender3 Quickstart:
> [10] Mapbender-Demo: https://demo.mapbender3.org/
> [11] Sandbox with opportunity to register:
> [12] Open tickets for the 3.0.6.1 Release:
>      https://github.com/mapbender/mapbender/issues?q=is%3Aopen+is%3Aissue+milestone%3A3.0.6.1
> German Version: Liebe Mapbender-Benutzer und Mapbender-Entwickler
> Heute haben wir die Version 3.0.6.0 von Mapbender3 veröffentlicht. Danke
> an dieser Stelle an alle Beteiligten.
> Es handelt sich um einen Feature-Release mit neuen Funktionalitäten und
> vielen Bugfixes. Ich möchte da einfach auf das Versions-Log in der
> Mapbender3 Dokumentation [1] verweisen
> (http://doc.mapbender3.org/de/book/versions.html), in der wir die Liste
> Kapitelweise zusammengefasst haben. Viele Änderungen betreffen die
> Codebasis, die an vielen Stellen aufgeräumt worden ist.
> Download [2]: http://mapbender3.org/?q=de/download oder direkt über den
> Link in Fußnote [3].
> - Die TAR.GZ Datei ist für Linux Systeme geeignet, denn sie nutzt
>   Symlinks im web/bundles Verzeichnis.
> - Die ZIP-Datei ist für Windows geeignet (und für Linux) und nutzt keine
>   Symlinks, da die nicht von Windows unterstützt werden.
> Source-Code [4]: https://github.com/mapbender/mapbender-starter
> Arbeiten mit dem Source-Code (Contributing.md) [5]:
> (liegt auch im Master-Branch)
> Melden von Fehlern [6]: https://github.com/mapbender/mapbender/issues
> Dokumentation [7]: http://doc.mapbender3.org/
> Installation und Update [8]:
> http://doc.mapbender3.org/de/book/installation.html
> Noch nie mit Mapbender3 gearbeitet [9]?
> http://doc.mapbender3.org/de/book/quickstart.html
> Mapbender-Demo [10]: https://demo.mapbender3.org/
> Sandbox mit Anmeldemöglichkeit [11]: https://sandbox.mapbender3.org/
> Neue Funktionen in diesem Release betreffen u.a. den Druck, den
> Digitizer, das Messen oder die Anzeige der Nutzer bei der Absicherung
> von Elementen. Wir mussten die Systemvoraussetzungen auf PHP 5.5.4 heben
> und verabschieden uns damit von der PHP 5.3 Schiene, die ja auch seit
> langer Zeit ihren Lebenszyklus abgeschlossen hat. Wir hatten zuerst
> vorgehabt, den Release als Bugfix-Release zu veröffentlichen, haben dies
> aber u.a. durch Auslagerung der Submodule (mapbender, fom, owsproxy) auf
> einen Feature-Release gehievt. Damit ist auch der Digitizer als Version
> 1.1 eingebaut.
> In der Zeit haben wir auch ein paar Dinge geschaffen, die es uns in der
> Zukunft ermöglichen, den Mapbender leichter zu aktualisieren und neue
> Funktionen leichter über Module zu realisieren. Daher finden Sie im
> Developer Teil der Dokumentation auf mapbender3.org [6] auch viele
> Verweise auf die Contributing.md [4], einer Hilfedatei für Entwickler
> und Entwicklerinnen und Fortgeschrittene, die wir direkt in den
> Source-Code des mapbender-starter gepackt haben, um diesen Nutzern einen
> leichteren Einstieg in den Mapbender zu ermöglichen. Ein typischer
> Entwickler kann diese Datei direkt in seiner Entwicklungsumgebung öffnen
> und lesen. Er oder sie wird sehen, dass der Mapbender sich mit ein paar
> Befehlen direkt einrichten und über den in Symfony eingebauten Webserver
> direkt starten lässt. Diese Contributing.md werden wir weiter fortführen
> und aktualisieren. Die Mapbender-Dokumentation wird sich dadurch mehr zu
> einer reinen Benutzerdokumentation entwickeln.
> Wie geht es weiter? Wir konnten einige strukturelle Grundlagen schaffen
> um häufigere Bugfix-Versionen zu veröffentlichen. Unsere Daumenregel ist
> etwa "2 Handvoll Bugs" oder etwa 2 Monate Zeit. Die Bugs und Fixes
> werden wir auf dem Issue Tracker auf Github dokumentieren. Wir arbeiten
> zur Zeit noch am Serverumzug unseres öffentlichen Testservers, auf dem
> wir - soweit möglich - in den Bugreports verweisen können.
> Feature-Versionen werden unregelmäßig veröffentlicht. Wir arbeiten zur
> Zeit auf dem 3.0.6 Branch und pflegen nebenher den 3.0.7 Branch mit, in
> dem diese Features dann eingebaut werden und aus dessen Code dann der
> nächste Feature-Release entstehen wird, mit den Bugfixes aus dem 3.0.6
> Branch. Features finden Sie im Issue-Tracker, wenn Sie nach der Version
> filtern [12]. Sie finden dort auch den 3.1 Branch, der größere
> Architektur-Änderungen mit sich bringen wird (Symfony Abhängigkeit und
> damit auch die Verzeichnisstuktur), von denen wir kleinere Teile aber
> schon in diesem Release umsetzen konnten.
> Links/Fußnoten:
> [1] Versionshistorie: http://doc.mapbender3.org/de/book/versions.html
> [2] Download: http://mapbender3.org/?q=de/download
> [3] Download der Builds: http://www.mapbender3.org/builds/
> [4] Download des Quellcodes:
> [7] Mapbender-Dokumentation: http://doc.mapbender3.org/
> [8] Installation: http://doc.mapbender3.org/de/book/installation.html
> [11] Sandbox mit Anmeldemöglichkeit: https://sandbox.mapbender3.org/
> [12] Offene Tickets für den 3.0.6.1 Release:
> Best regards, viele Grüße
> The Mapbender Team
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
