document.getElementById(tab_ids[i])
Anna S. a.smit at gmx.net
Wed Apr 12 11:04:03 EDT 2006
I've tried to create a treeGDE folder using treeConfGDE in Mapbender 2.2.2
but now I've problems with displaying any layer in the mapframe. The
Javascipt Console reports the following error:
"document.getElementById(tab_ids[i]) has no properties"
If I try to redraw the mapframe: there comes a map, however the Javascipt
Console notifies:
"mb_mapObj(ind) has no properties"
"mb_button(ind) has no properties"
I've even defined some layers with "sel_default" in "Edit GUI-WMS". When I
try to check a layer directly in the treeConfGDE tool it doesn't work.
I'm looking forward to get some hints!
Yours thankfully,
Anna
View this message in context: http://www.nabble.com/document.getElementById%28tab_ids-i-%29-t1438610.html#a3883295
Sent from the mapbender-users forum at Nabble.com.
More information about the Mapbender_users mailing list
