[Mapbender-users] the mapbender installation stuck on half way
smithveg smithveg at gmail.com
Thu Aug 10 07:58:09 EDT 2006
Ok, thanks for your helps. I can login now and see a table.
Then i try to click any of it in the table, it give me the error as below:
This GUI is an OGC service catalog container and does not provide a map user
interface. Please use the (back <javascript:history.back()>) link to select
another GUI form your list or log off to log on using another account
(identity).
Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm was
Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie diesen
(back<javascript:history.back()>)
Verweis, um aus der Liste eine andere GUI auszuwählen oder melden Sie sich
ab, um sich mit einer anderen Kennung anzumelden.
in addition, the insert statement as below correct or not?
postgres=# INSERT INTO
mb_user(mb_user_id,mb_user_name,mb_user_password,mb_user_
owner,mb_user_description,mb_user_login_count)
VALUES(5,'admin1','admin1',1,'adm
in',5);
INSERT 0 1
postgres=#-
On 8/10/06, Lars-Hendrik Schneider <schneider at terrestris.de> wrote:
> go into the DB and look for table mb_user and then user root. there is
> afield called mb_user_login_count. Set this field back to zero.
> short description: it is increased by one everytime you do a failing
> login. After 4 tries your account ist deactivated....
> then try again with root/root
> hth,
> lars-hendrik
> smithveg schrieb:
> > oh my god!
> > I did tried it, 'roor' for username and password. I also cannot walk.
> > By now, i prompt me the error as below:
> > Permission denied. Login failed 3 times. Your account has been
> > deactivated. Please contact your administrator!
> > Where can i reset it....
> terrestris Till Adams & Hinrich Paulsen GbR
> Diplom-Geograph
> Siemensstr. 8
> D-53121 Bonn
> Telefon: +49 (0)228 - 962 899 53
> Fax: +49 (0)228 - 962 899 57
> E-Mail: schneider at terrestris.de
> Internet: http://www.terrestris.de
> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: users-help at mapbender.osgeo.org
smithveg
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060810/13ce77c4/attachment.html
More information about the Mapbender_users mailing list
