AW: [Mapbender-users] Mapbender Fehlermeldung
ProAlp - Gotthard scalet.gotthard at proalp.at
Fri Aug 11 05:24:55 EDT 2006
Yes, i am new to Mapbender!
I open the Site mapbender/tools/mapbender_setup.php, the Site looks like
this
Administration Database	 Connect to Database	 PostGIS support	 md5
PostgreSQL	 on	 on: VERSION 1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
md5 support
File to start Mapbender:  <http://localhost/mapbender/frames/login.php>
The Error comes when i klick on the Link below the Table. (
http://localhost/mapbender/frames/login.php)
  _____
Von: smithveg [mailto:smithveg at gmail.com]
Gesendet: Freitag, 11. August 2006 11:11
An: users at mapbender.osgeo.org
Betreff: Re: [Mapbender-users] Mapbender Fehlermeldung
http://babel.altavista.com
I'm not sure what's the error with 'preg_match()'. Could you provides more
information, how you get the error, any steps? So that we may helps you.
Basically, the error is the solutions. I means the error something will tell
you what to do.
Hopes this helps....
Are you new to mapbender?
smith
On 8/11/06, ProAlp - Gotthard <scalet.gotthard at proalp.at> wrote:
Hallo,
Beim Starten des Mapbender unter FreeBsd bekomme ich folgende fehlermeldung:
Fatal error: Call to undefined function preg_match() in
/usr/local/www/data-dist/mapbender/http/php/mb_validateInput.php on line 26
Was kann da die Ursache sein?
Gotthard
To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
<mailto:users-unsubscribe at mapbender.osgeo.org>
For additional commands, e-mail: users-help at mapbender.osgeo.org
smithveg
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060811/65064efb/attachment.html
More information about the Mapbender_users mailing list
