[Mapbender-users] where to get the map
smithveg smithveg at gmail.com
Fri Aug 11 08:19:09 EDT 2006
nice, thanks, i have a deep understand, is it i need to find the WMS and get
the map url, and then load capabilities?
If i can get the map to load in, like different country's map.
Can i edit/add the point (road name, building name) into it?
I can't really see any add/edit button in gui
As for user, how they access the map?
On 8/11/06, "Jäger, Frank \(KRZ\)" <F.Jaeger at krz.de> wrote:
>  Hallo,
> I try to explain:
> a GUI can have GUI-elements (Buttons ...) and WMS.
> A WMS can be used in many GUIs.
> In every GUI the Parameters of the WMS can be changed (for example
> Minscale / Maxscale, make a Layer invisible).
> You can copy a WMS from one GUI to another, the changed parameters will be
> copied too.
> In the end you will not know, what the original Parameters of the WMS
> were.
> So it's a good practice to do so:
> Create a GUI with NO elements.
> This GUI can't be shown in a Browser (the error message you got), don't
> give it to Users, it's Admin-Only.
> It's only a "Container" in which you load your WMS by "GetCapabilities".
> Don't change any Parameters of WMS there.
> Copy the WMS to another GUI (with Elements, like "gui1").
> In this User-GUI you change the WMS-Parameters to your needs.
> The Container-GUIs for WMS have a Name like "wms_ .."
> The next time you have to copy a WMS you can copy from …
> the original WMS from gui "wms_.." and make new changes to it
> or
> changed WMS (when the same changes will be OK).
> Greetings
> Frank
> *Von:* smithveg [mailto:smithveg at gmail.com]
> *Gesendet:* Freitag, 11. August 2006 12:26
> *An:* users at mapbender.osgeo.org
> *Betreff:* Re: [Mapbender-users] where to get the map
> Thank for your information. I had getting me to built up some
> understanding about GIS and WMS.
> While in the admin panel, i see a list of mapbender gui.
> i undertsnad the gui with 'admin' prefix is admin control.
> then gui, gui1, gui2 is map of germany. I don't understand those prefix
> with 'WMS_...'.
> Most of the gui wthose start with WMS give me the error as below:
> This GUI is an OGC service catalog container and does not provide a map
> user interface. Please use the ( back) link to select another GUI form
> your list or log off to log on using another account (identity).
> Secondly, let's say click in 'gui' or 'gui1', or 'gui2'. it shown me the
> map, But i wonder to know how can i add a dot, add a location name, ( i
> means add something inside the map).
> Thanks for reply.
> Thank you.
> smith
>  On 8/11/06, *Lars-Hendrik Schneider* <schneider at terrestris.de > wrote:
> Hi
> smithveg schrieb:
> > Hello,
> > I download a zip file form the url as below:
> > http://www.cipotato.org/DIVA/data/DataServer.htm
> > Inside got a GRD and GRI file. I'm not sure how to use it. Is it get the
> > map and upload to mapbender?
> > But you say that mapbender not display the map for user, so, who display
> > the map? WMS?
> Mapbender is only a client software that enabels you to get maps
> (images) from specialized mapserver services. In the backend Mapbender
> only (simply spoken) creates special URL requests to a program that
> delivers and creates the map then. Mapbender does not create the maps
> itself.
> For the maps you need the data (shapes, aeral photos, TIFs ...) and a
> program that takes a picture from your data and delivers it to a client
> (Mapbender). Therefore you need s.th. like UMN Mapserver or ArcIMS.
> So you currently just have the "remote control" for such kind of
> servers. Luckily many such servers are available in the internet and can
> be accessed by delivering their data in a standard format -> WMS (Web
> Map Service).
> There you can a file that tells Mapbender which parameters the service
> expects - so that you can get maps from such a service using Mapbender
> as a remote control.
> Hth a bit for the background...
> Lars-Hendrik
> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: users-help at mapbender.osgeo.org
> smithveg
smithveg
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060811/4117729f/attachment.html
More information about the Mapbender_users mailing list
