load capabilities without getFeatureInfo?
    Christoph Ratke
    ratke at geoinformationsdienst.de
    Tue Sep 12 10:00:00 EDT 2006
Hi list,
did the wms-upload module change between versions 2.2 and 2.4? I tried
to load a wms into Mapbender version 2.4 which is not capable of
getFeatureInfo-Requests and thus has not such tags in the capabilities
xml. I received the following error message:
*Warning*: pg_execute() [function.pg-execute
<http://polaris30/mb24/php/function.pg-execute>]: Query failed: ERROR:
null value in column "wms_getfeatureinfo" violates not-null constraint
in */var/www/mapbender/http/php/database-pgsql.php* on line *167*
sql error: ERROR: null value in column "wms_getfeatureinfo" violates
not-null constraint ROLLBACK performed....
The same WMS worked well in version 2.2.
I actually have no time to check the code myself so I just wanted to
report this failure.
Best regards,
Christoph
Christoph Ratke
GeoInformationsDienst GmbH
Götzenbreite 10
37124 Rosdorf
fon:    ++49-(0)551-78904-25
eMail:  ratke at geoinformationsdienst.de
web:    www.geoinformationsdienst.de
More information about the Mapbender_users
