[Mapbender-users] problem with wms after importing gui on server
karsten vennemann karsten at terragis.net
Sat Dec 29 03:04:01 EST 2007
Hi list,
I'm working with mapbender 2.4.3 and created a gui including one wms
(http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/projects/
alliance/ok_server.map
<http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/projects/
alliance/ok_server.map&> &) on my local windows machine. There all is
working fine. I then exported the gui as sql and imported into the mapbender
database (postgis) on my linux server. The gui shows up on the admin pages
after I ran
Insert into gui_mb_user Values ('ocla1',1,'owner');
However, the wms does not show up when I load the gui, also I can't find my
wms in the table "wms" nor does it show up when I try to edit the wms under
Configue WMS access> WMS GUI settings in the WMS_TiTle list box.
I don't know whether a wms belonging to a gui usually is exported with the
gui  - or whether I have to recreate that resource on the server again?
Thus, I tried to recreate the wms with "load capabilities", however trying
to load
http://alliance.terragis.net/cgi-bin/mapserv?map=/var/www/mapdata/projects/a
alliance/ok_server.map&REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0>
gives me a violation of a constraint :-(:
Warning: pg_exec() [function.pg-exec
<http://alliance.terragis.net/php/function.pg-exec> ]: Query failed: ERROR:
duplicate key violates unique constraint "pk_gui_layer" in
/var/www/sites/mapbender/http/php/database-pgsql.php on line 133
sql error: ERROR: duplicate key violates unique constraint "pk_gui_layer"
ROLLBACK performed....
Now I'm stuck and don't know how to port gui and wms to the server. Any
ideas what went wrong, or how I can fix this?
Karsten
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20071229/ccd472a8/attachment.html
More information about the Mapbender_users mailing list
