[Mapbender-users] failure notice
MAILER-DAEMON at mx0.gmx.net MAILER-DAEMON at mx0.gmx.net
Mon Jan 8 03:10:37 EST 2007
Hi. This is the qmail-send program at mx0.gmx.net.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<makrohard at gmx.de>:
User_doesn't_want_to_receive_mails_from_your_address_-_Dieser_User_moechte_keine_Mails_von_Ihrer_Absenderadresse_empfangen/
--- Below this line is a copy of the message.
Return-Path: <mapbender_users at lists.osgeo.org>
Received: (qmail invoked by alias); 08 Jan 2007 08:10:37 -0000
Received: from darkstar.lwf.uni-muenchen.de (EHLO kim.lwf.uni-muenchen.de) [141.40.111.5]
  by mx0.gmx.net (mx075) with SMTP; 08 Jan 2007 09:10:37 +0100
Received: from lwf.uni-muenchen.de (unknown [10.141.1.10])
	by kim.lwf.uni-muenchen.de (Postfix) with ESMTP id 7EA652AD94
	for <makrohard at gmx.de>; Mon,  8 Jan 2007 09:09:08 +0100 (CET)
Received: from KANE/SpoolDir by lwf.uni-muenchen.de (Mercury 1.48);
    8 Jan 07 09:10:36 +0100
Received: from SpoolDir by KANE (Mercury 1.48); 8 Jan 07 09:10:28 +0100
  for <loose.AB1.LWF at lwf.uni-muenchen.de>;  8 Jan 07 09:10:18 +0100
Resent-From: loose.AB1.LWF at lwf.uni-muenchen.de
Resent-To: makrohard at gmx.de
Resent-Date: Mon, 8 Jan 2007 9:10:18 +0100
X-Autoforward: 1
Received: from kim.lwf.uni-muenchen.de (10.42.1.5) by lwf.uni-muenchen.de (Mercury 1.48) with ESMTP;
    8 Jan 07 09:10:10 +0100
Received: from mailrelay1.lrz-muenchen.de (mailrelay1.lrz-muenchen.de [129.187.254.106])
	by kim.lwf.uni-muenchen.de (Postfix) with ESMTP id 036A82AD94
	for <loose at lwf.uni-muenchen.de>; Mon,  8 Jan 2007 09:08:42 +0100 (CET)
Received: from lxmhs06.lrz-muenchen.de (lxmhs06.lrz-muenchen.de [10.156.6.203]) by mailrelay1.lrz-muenchen.de with ESMTP for loose at lwf.uni-muenchen.de; Mon, 8 Jan 2007 09:10:09 +0100
X-Virus-Scanned: by amavisd-new at lrz-muenchen.de in 06
X-Spam-Score: 0.198
X-Spam-Level:
X-Spam-Status: No, score=0.198 tagged_above=-999 required=5 tests=[AWL=0.062,
	BAYES_50=0.001, FORGED_RCVD_HELO=0.135]
Received: from mailrelay1.lrz-muenchen.de ([10.156.6.201])
	by lxmhs06.lrz-muenchen.de (lxmhs06.lrz-muenchen.de [10.156.6.203]) (amavisd-new, port 10024)
	with ESMTP id MLGsblnHOAes for <loose at lwf.uni-muenchen.de>;
	Mon,  8 Jan 2007 09:10:09 +0100 (CET)
Received: from lists.osgeo.org (lists.osgeo.org [66.223.95.242]) by mailrelay1.lrz-muenchen.de with ESMTP for loose at lwf.uni-muenchen.de; Mon, 8 Jan 2007 09:10:07 +0100
Received: from osgeo1.osgeo.org (localhost.localdomain [127.0.0.1])
	by lists.osgeo.org (Postfix) with ESMTP id 2775512A8005;
	Mon,  8 Jan 2007 04:06:38 -0500 (EST)
X-Original-To: mapbender_users at lists.osgeo.org
Delivered-To: mapbender_users at lists.osgeo.org
Received: from mx1.simplethings.de (unknown [85.88.4.197])
	by lists.osgeo.org (Postfix) with ESMTP id 69C7812A8002
	for <mapbender_users at lists.osgeo.org>;
	Mon,  8 Jan 2007 04:06:36 -0500 (EST)
Received: from smm.simplethings.local ([192.168.0.11] helo=smM.simplethings.de)
	by mx1.simplethings.de with esmtp (Exim 4.50) id 1H3pZF-0002v2-OB
	for mapbender_users at lists.osgeo.org; Mon, 08 Jan 2007 09:09:18 +0100
Received: from [212.79.172.180] (helo=center.shared)
	by smM.simplethings.de with esmtpsa (TLS-1.0:RSA_AES_256_CBC_SHA:32)
	(Exim 4.50) id 1H3pZ2-00053w-VV
	for mapbender_users at lists.osgeo.org; Mon, 08 Jan 2007 09:09:05 +0100
Received: from [192.168.4.184] (helo=[192.168.4.184])
	by center.shared with esmtp (Exim 4.50) id 1H3pYj-0003SO-HB
	for mapbender_users at lists.osgeo.org; Mon, 08 Jan 2007 09:08:45 +0100
Message-Id: <45A1FB0F.7020303 at terrestris.de>
Date: Mon, 08 Jan 2007 09:04:31 +0100
User-Agent: Mozilla Thunderbird 1.0.7 (X11/20050923)
X-Accept-Language: de-DE, de, en-us, en
MIME-Version: 1.0
To: Mapbender Users Help each Other <mapbender_users at lists.osgeo.org>
Subject: Re: [Mapbender-users] Problem to present a WFS-Layer in the Mapbender
References: <20070106204811.19910 at gmx.net>
In-Reply-To: <20070106204811.19910 at gmx.net>
Content-Type: text/plain; charset=UTF-8; format=flowed
X-BeenThere: mapbender_users at lists.osgeo.org
X-Mailman-Version: 2.1.5
Precedence: list
Reply-To: Mapbender Users Help each Other <mapbender_users at lists.osgeo.org>
List-Id: Mapbender Users Help each Other <mapbender_users.lists.osgeo.org>
List-Unsubscribe: <http://lists.osgeo.org/mailman/listinfo/mapbender_users>,
	<mailto:mapbender_users-request at lists.osgeo.org?subject=unsubscribe>
List-Archive: <http://lists.osgeo.org/pipermail/mapbender_users>
List-Post: <mailto:mapbender_users at lists.osgeo.org>
List-Help: <mailto:mapbender_users-request at lists.osgeo.org?subject=help>
List-Subscribe: <http://lists.osgeo.org/mailman/listinfo/mapbender_users>,
	<mailto:mapbender_users-request at lists.osgeo.org?subject=subscribe>
Sender: mapbender_users-bounces at lists.osgeo.org
Errors-To: mapbender_users-bounces at lists.osgeo.org
Content-Transfer-Encoding: quoted-printable
Resent-Message-Id: <20070108080908.7EA652AD94 at kim.lwf.uni-muenchen.de>
X-Y-GMX-Trusted: 0
Kai,
das Problem des WFs liegt darin, da=C3=9F man ihn nicht sieht ...;-) Zur=20
Kartenanzeige gibt es ja den WMS.
Der WFs dient dir nur f=C3=BCr Dinge wie Suchen, Onmouseover=20
Highlighten,digitalisieren (WFS-T) u.=C3=A4. -- sprich
Anwendungen, in denen die echten Geodaten ben=C3=B6tigt werden.
Wenn du den WFS unbedingt sehen willst, kannst du ihn ja als=20
Datenquwelle in einen WMS einbinden.
Gr=C3=BCsse, Till
Kai,
the thing with theWFsi s, that you won't see it - therefore the WMS exist=
s.
The WFS loads the geodata to the client and allows stuff like=20
gazetteers, highlighting of objects or digitizing (WFS-T).
If you really nered to see the WFS then use it as datasource for a WMS,
greetings, Till
Kai Behncke schrieb:
>Hallo Liste,
>ich bin gerade dabei ein Tutorium zum Thema WMS/WFS zu erstellen, welche=
s nach Fertigstellung auch der Allgemeinheit zur Verf=C3=BCgung stehen so=
ll.
>Den Nutzen eines WFS m=C3=B6chte ich gerne praktisch am Beispiel des Map=
benders erl=C3=A4utern.
>Hier stecke ich aber leider im Augenblick fest und habe eine ganze Menge=
 Fragen.
>Wie kann ich einen ganz einfachen WFS-Layer im Mapbender darstellen???
>Folgendes habe ich gemacht:
>Im UMN MapServer einen WFS-Server erstellt.
>Die Capabilities kann ich auch wunderbar =C3=BCber:
>http://localhost/cgi-bin/mapserv?map=3D/mapservertest/wfs/wfs_hope/mapda=
tei_wfs_server.map&REQUEST=3DGetCapabilities&VERSION=3D1.0.0&Service=3DWF=
S
>abfragen. Wenn ich den Mapserver als WFS-Client nutze, dann wird der WFS=
 auch dargestellt.
>Im Mapbender habe ich einfach die Standardgui (gui) kopiert und =E2=80=9C=
gui_wfs=E2=80=9D genannt,  alle WMS habe ich gel=C3=B6scht.
>Ich m=C3=B6chte, dass nur die Polygone meines einzubindenden WFS pr=C3=A4=
sentiert werden.
>Ich habe dann unter admin1-> Load WFS  einen WFS eingespielt, so weit ic=
h beurteilen kann mit Erfolg.
>Etwas wie der "Ochs vorm Berg" stehe ich dann aber im Bereich "WFS Conf"=
>Die Seite:http://www.mapbender.org/index.php/WFS_Konfiguration
>hilft mir zwar etwas weiter, aber der entscheidende Schritt fehlt noch.
>Was muss ich denn hier eintragen, damit die Poylgone des WFS auch in der=
 Anwendung pr=C3=A4sentiert werden? K=C3=B6nnte mir da jemand ein Beispie=
l geben?
>Und eine generelle Frage:
>Muss ich eigentlich in die gui unter "Oberfl=C3=A4che editieren" noch Mo=
dule f=C3=BCr eine Pr=C3=A4sentation des WFS einbinden?
>Im Augenblick habe ich, wie in der "gui_digitize" z.B.
>noch  ../extensions/wz_jsgraphics.js & wfs.js=20
>sowie ../php/mod_wfs.php eingebunden, leider ohne Resultat.
>Wenn ich jetzt die "gui_wfs" im Mapbender =C3=B6ffne, dann wird keine Ka=
rte (auch kein Kartenfenster) angezeigt?
>Kann mir da jemand auf die Spr=C3=BCnge helfen?
>Ich nutze mapbender 2.2.4 unter Debian Sarge 3.1.
>Danke im Voraus, Kai
>Hello list,
>I have got a problem to present a simple WFS-Layer in the Mapbender.
>The following I have done:
>I constructed a WFS-Server in the UMN MapServer.
>Without any problems I get its capabilities by that url:
S
>If I use the MapServer as WFS-Client I can present the map very well.
>In the Mapbender I copied the standard-gui (gui) and named it to =E2=80=9C=
gui_wfs=E2=80=9D.
>I deleted all the WMS-Layers, I want, that just the new WFS-Layer will b=
e presented.
>Then I loaded (as I think successfully) the new WFS.
>The problem begins in the area "WFS Conf".
>The site: :http://www.mapbender.org/index.php/WFS_Konfiguration
>helps, but nevertheless I don`t know what to fill in exactly, could anyb=
ody give me an example? What do I have to do, that the WFS is presented i=
n the map??What do I have to configure?
>A generell question: Is it needable that I load in some moduls for the p=
resentation of a WFS?
>So far, I loaded (like in the gui_digitize)  ../extensions/wz_jsgraphics=
.js & wfs.js=20
>and ../php/mod_wfs.php to, unfortunatelly without result.
>If I open now the "gui_wfs" in the Mapbender, there is no map at all, no=
t even a mapframe.
>I`m using Mapbender 2.2.4 on Debian Sarge 3.1.
>Could anybody help please? Thank you very much.
>Kai
> =20
--=20
*    SensorGIS 'Geodaten in Echtzeit'		*
*        http://www.sensorgis.de	 		*
*        http://www.terrestris.de	 		*
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
More information about the Mapbender_users mailing list
