[Mapbender-users] failure notice
MAILER-DAEMON at mx0.gmx.net MAILER-DAEMON at mx0.gmx.net
Wed Jan 10 07:03:34 EST 2007
Hi. This is the qmail-send program at mx0.gmx.net.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<makrohard at gmx.de>:
User_doesn't_want_to_receive_mails_from_your_address_-_Dieser_User_moechte_keine_Mails_von_Ihrer_Absenderadresse_empfangen/
--- Below this line is a copy of the message.
Return-Path: <mapbender_users at lists.osgeo.org>
Received: (qmail invoked by alias); 10 Jan 2007 12:03:34 -0000
Received: from darkstar.lwf.uni-muenchen.de (EHLO kim.lwf.uni-muenchen.de) [141.40.111.5]
  by mx0.gmx.net (mx072) with SMTP; 10 Jan 2007 13:03:34 +0100
Received: from lwf.uni-muenchen.de (unknown [10.141.1.10])
	by kim.lwf.uni-muenchen.de (Postfix) with ESMTP id 710E42AD8B
	for <makrohard at gmx.de>; Wed, 10 Jan 2007 13:01:39 +0100 (CET)
Received: from KANE/SpoolDir by lwf.uni-muenchen.de (Mercury 1.48);
    10 Jan 07 13:03:34 +0100
Received: from SpoolDir by KANE (Mercury 1.48); 10 Jan 07 13:03:31 +0100
  for <loose.AB1.LWF at lwf.uni-muenchen.de>;  10 Jan 07 13:03:31 +0100
Resent-From: loose.AB1.LWF at lwf.uni-muenchen.de
Resent-To: makrohard at gmx.de
Resent-Date: Wed, 10 Jan 2007 13:03:31 +0100
X-Autoforward: 1
Received: from kim.lwf.uni-muenchen.de (10.42.1.5) by lwf.uni-muenchen.de (Mercury 1.48) with ESMTP;
    10 Jan 07 13:03:28 +0100
Received: from mailrelay1.lrz-muenchen.de (mailrelay1.lrz-muenchen.de [129.187.254.106])
	by kim.lwf.uni-muenchen.de (Postfix) with ESMTP id 0B5122AD8B
	for <loose at lwf.uni-muenchen.de>; Wed, 10 Jan 2007 13:01:34 +0100 (CET)
Received: from lxmhs06.lrz-muenchen.de (lxmhs06.lrz-muenchen.de [10.156.6.203]) by mailrelay1.lrz-muenchen.de with ESMTP for loose at lwf.uni-muenchen.de; Wed, 10 Jan 2007 13:03:27 +0100
X-Virus-Scanned: by amavisd-new at lrz-muenchen.de in 06
X-Spam-Score: 0.122
X-Spam-Level:
X-Spam-Status: No, score=0.122 tagged_above=-999 required=5 tests=[AWL=0.121,
	BAYES_50=0.001]
Received: from mailrelay1.lrz-muenchen.de ([10.156.6.201])
	by lxmhs06.lrz-muenchen.de (lxmhs06.lrz-muenchen.de [10.156.6.203]) (amavisd-new, port 10024)
	with ESMTP id ubSkEa+9okS8 for <loose at lwf.uni-muenchen.de>;
	Wed, 10 Jan 2007 13:03:27 +0100 (CET)
Received: from lists.osgeo.org (lists.osgeo.org [66.223.95.242]) by mailrelay1.lrz-muenchen.de with ESMTP for loose at lwf.uni-muenchen.de; Wed, 10 Jan 2007 13:03:26 +0100
Received: from osgeo1.osgeo.org (localhost.localdomain [127.0.0.1])
	by lists.osgeo.org (Postfix) with ESMTP id 93CF312A801A;
	Wed, 10 Jan 2007 08:00:00 -0500 (EST)
X-Original-To: mapbender_users at lists.osgeo.org
Delivered-To: mapbender_users at lists.osgeo.org
Received: from medusa.tops.net (unknown [212.79.160.64])
	by lists.osgeo.org (Postfix) with ESMTP id 7CB0212A8002
	for <mapbender_users at lists.osgeo.org>;
	Wed, 10 Jan 2007 07:59:58 -0500 (EST)
Received: by medusa.tops.net (Postfix, from userid 111)
	id DF29D1C0011E9; Wed, 10 Jan 2007 13:02:33 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by medusa.tops.net (Postfix) with ESMTP id 271DA1C001A1E
	Wed, 10 Jan 2007 13:02:31 +0100 (CET)
X-Virus-Scanned: Debian amavisd-new at medusa.tops.net
Received: from medusa.tops.net ([127.0.0.1])
	by localhost (medusa.tops.net [127.0.0.1]) (amavisd-new, port 10024)
	with ESMTP id hyPZ7RFfhXTs for <mapbender_users at lists.osgeo.org>;
Received: from [192.168.4.184] (unknown [212.79.172.180])
	(Authenticated sender: adams at terrestris.de)
	by medusa.tops.net (Postfix) with ESMTP id F055B1C0011E9
	Wed, 10 Jan 2007 13:02:30 +0100 (CET)
Message-Id: <45A4D4C3.1010000 at terrestris.de>
Date: Wed, 10 Jan 2007 12:57:55 +0100
User-Agent: Mozilla Thunderbird 1.0.7 (X11/20050923)
X-Accept-Language: de-DE, de, en-us, en
MIME-Version: 1.0
To: Mapbender Users Help each Other <mapbender_users at lists.osgeo.org>
Subject: Re: AW: Antw: Re: [Mapbender-users] Probleme mit Darstelllung im
	Internet	Explorer 7
References: <E7E585481075EA4B8ECD4B8965814679AE547A at w3kmail2.stadt.wolfsburg.de>
In-Reply-To: <E7E585481075EA4B8ECD4B8965814679AE547A at w3kmail2.stadt.wolfsburg.de>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
X-BeenThere: mapbender_users at lists.osgeo.org
X-Mailman-Version: 2.1.5
Precedence: list
Reply-To: Mapbender Users Help each Other <mapbender_users at lists.osgeo.org>
List-Id: Mapbender Users Help each Other <mapbender_users.lists.osgeo.org>
List-Unsubscribe: <http://lists.osgeo.org/mailman/listinfo/mapbender_users>,
	<mailto:mapbender_users-request at lists.osgeo.org?subject=unsubscribe>
List-Archive: <http://lists.osgeo.org/pipermail/mapbender_users>
List-Post: <mailto:mapbender_users at lists.osgeo.org>
List-Help: <mailto:mapbender_users-request at lists.osgeo.org?subject=help>
List-Subscribe: <http://lists.osgeo.org/mailman/listinfo/mapbender_users>,
	<mailto:mapbender_users-request at lists.osgeo.org?subject=subscribe>
Sender: mapbender_users-bounces at lists.osgeo.org
Errors-To: mapbender_users-bounces at lists.osgeo.org
Content-Transfer-Encoding: quoted-printable
Resent-Message-Id: <20070110120139.710E42AD8B at kim.lwf.uni-muenchen.de>
X-Y-GMX-Trusted: 0
Roland,
dasselbe Problem hatten wir auch - es trat aber im Zusammenhang mit dem=20
UMN v4.10 auf!
Wir hatten einen Bildkatalog gebaut, und an einer Schnittkante wurde=20
eine Kachel unvollst=E4ndig geladen, sobald man das Bild so verschoben=20
hatte, das > 50% der entsprechenden Kachel angefordert wurden, war der=20
Balken weg. Verschob man es wieder so, da=DF <50% der Kachel angefordert=20
wurden, war er wieder da. Und das nur an einer =DCbergangsstelle=20
(gl=FCcklicherweise immer dieselbe) - bei allen anderen =DCberg=E4ngen ni=
cht.
Das fanden wir sehr seltsam, haben dies dann aber per Workaround so=20
umgangen, da=DF wir nicht mehr den Bildkatalog verwenden, sondern die 12=20
Kacheln einzeln als RASTER eingebunden haben. Dann war der Effekt weg.=20
---> Frag nicht ;-)
Gr=FCsse, Till
Burghardt.Scholle at stadt.wolfsburg.de schrieb:
>Hallo Ronald,
>ich muss Mike zustimmen. Auch ich habe bei der Verwendung vom IE7 keine =
Probleme auf Euren Seiten. Den von Dir beschriebenen Effekt kann ich nich=
t nachvollziehen.
>Ein kurzer Gegencheck mit Linien- / Punkt-WMS auf unseren eigenen (lokal=
en) Seiten best=E4tigt diese positiven Erfahrungen. Keine Darstellungspro=
bleme mit dem IE7.
>Liegt das Problem eventuell an Deinem IE7-Rechner? Tritt das Ph=E4nomen =
bei anderen Clients mit IE7 auch auf?
>Gru=DF
>Burghardt Scholle
>-----Urspr=FCngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org]Im Auftrag von Ronald
>Woita
>Gesendet: Mittwoch, 10. Januar 2007 12:09
>An: mapbender_users at lists.osgeo.org
>Betreff: Antw: Re: [Mapbender-users] Probleme mit Darstelllung
>imInternet Explorer 7
>Hallo Mike,=20
>das ist gerade mein Problem- ich kann nicht nachvollziehen, wann bzw. wa=
rum dieser Fehler auftritt ?!
>hier der Effekt als Screenshot :
>http://kataster.sv.rostock.de/info/ie7_bug03.png
>W=E4re sch=F6n, wenn ich noch ein paar R=FCckmeldungen ob des Auftretens=
 des Fehlers bekommen k=F6nnte !
>Danke=20
>Ronald
>Ronald Woita
>http://geoportal.rostock.de
>Hansestadt Rostock
>Kataster-, Vermessungs- und Liegenschaftsamt
>Holbeinplatz 14, 18069 Rostock
>email: ronald.woita at rostock.de=20
>phone: +49 (0)381 - 381 6256
> =20
>>>>Wigold at aol.com 10.01.2007 11:38:10 >>>
>>>>       =20
> =20
>>In einer eMail vom 10.01.2007 10:25:32 Westeurop=E4ische Normalzeit sch=
reibt =20
>>Ronald.Woita at rostock.de:=20
>>ich habe  seit der Einf=FChrung des Internet Explorer 7 Probleme mit de=
r=20
>>Darstellung der  Webdienste in meiner Mapbender-Installation; das Ph=E4=
nomen: beim=20
>>=DCberlagern von  Punkt-bzw Linienlayern entstehen wei=DFe Balken quer =
=FCber die=20
>>Karten (zu sehen  http://geoportal.rostock.de , mal das Thema Verkehr/S=
tra=DFenbahn=20
>>zum Stadtplan  zuschalten)
>>   =20
>Hi Ronald,
>=20
>ich muss sagen, dass ich Dein Problem nicht nachvollziehen kann, denn be=
i =20
>mir werden trotz der Verwendung des IE7 keine wei=DFen Streifen angezeig=
t. Die =20
>Karte sieht folglich ganz normal aus, auch wenn der Stra=DFenbahn-Layer =
=20
>eingeschaltet ist.
>=20
>Gru=DF
>Mike
>_______________________________________________
>Mapbender_users mailing list
>Mapbender_users at lists.osgeo.org
> =20
--=20
     SensorGIS 'Geodaten in Echtzeit'	=09
        http://www.sensorgis.de	 	=09
         http://www.terrestris.de	 	=09
Dipl. Geogr. Till Adams
terrestris, H. Paulsen& T. Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * http://www.terrestris.de
More information about the Mapbender_users mailing list
