[Mapbender-users] IE vs. Firefox - map repaint with the space bar
Rogozia, Juergen Juergen.Rogozia at gkd-rso.de
Thu Jul 19 03:55:46 EDT 2007
Hi Uli!
Thank you! I invite you to a beer next time I see you in the "Pawlow" :-)
After I disabled the "keyHandler" for IE everything works fine. In GUI2 it is enabled by default (in mapbender 2.4.1).
Best wishes
Juergen
Date: Wed, 18 Jul 2007 15:51:04 +0200
From: "Uli Rothstein (WhereGroup)" <uli.rothstein at wheregroup.com>
Subject: Re: [Mapbender-users] IE vs. Firefox - map repaint with the
	space bar
To: Mapbender User List <mapbender_users at lists.osgeo.org>
Message-ID: <469E1AC8.6050207 at wheregroup.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hi Juergen,
maybe you have enabled a deprecated module called "keyHandler" for IE. Please
check your gui-elements settings and disable/delete(!) this module.
regards
Uli
Rogozia, Juergen schrieb:
> Hallo list!
> We are using mapbender 2.4.1 with some our own GUI, which is based on
> the original GUI2. Everything works fine with firefox (like most of the
> time) but with IE7 we discovered a strange event-behavior.
> We are using our own AJAX-streetsearch form. It listens to events in a
> form field and behaves like it should - with firefox. With the IE7 the
> form does not work. The reason (I think) is, that the IE7 is listening
> to a event which will do a repaint after pressing the space bar. Is
> there a way to switch that off?
> After I manually reload the AJAX-form everything works fine and for e.g.
> pressing the spacebar while filling out the form has no repaint-effect.
> Many thanks in advance
> Juergen
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Jürgen Rogozia
Zweckverband GKD
Rhein-Sieg / Oberberg
e-mail:  juergen.rogozia at gkd-rso.de
Tel.: 02241 / 999 1315
Fax.: 02241 / 999 2 1315
More information about the Mapbender_users mailing list
