[Mapbender-users] load WMC problems
Christoph Ratke ratke at geoinformationsdienst.de
Fri Jul 20 06:48:33 EDT 2007
Hi Christoph,
thanks for your answer, that is good to know. I should have better read
the WMC spec before.
Maybe you could add a short note in the wiki that the WMC spec is
limiting the Mapbender capabilities.
regards,
Christoph
Am Freitag, den 13.07.2007, 16:38 +0200 schrieb Christoph Baudson
(WhereGroup):
> Christoph Ratke schrieb:
> > Hi list,
> > I tested the load WMC module (version 2.4.2 Rc1). Two things are not
> > working correctly:
> > 1. After load, ZoomFull is not working correctly. The complete map
> > boundaries are overwritten by the WMC extend.
> True. The problem is, that there is only one field in a WMC for storing
> the extent. This is the current extent of the mapframe.
> A possible solution would be storing the initial extent in an extension.
> like this
> <layer ...>
> <extensions>
> <mapbender:layer_extent>
> </mapbender:layer_extent>
> </extensions>
> </layer>
> > 2. When I have grouped layers in the TreeGDE2 (ok, did not test it with
> > another tree module), the sublayers are listed in the layer tree after
> > the load (was not the case before saving the WMC). I found something
> > similar in the trac (#2) but I am not sure if it is the same problem.
> > It is not fixed yet, is it?
> The WMC can only stores layers without hierachy. It is therefore
> impossible to map the Mapbender layer hierachy into the WMC. Possible
> solution again: extensions.
> However I'm not sure about using lots of extensions, as it is somehow
> contrary to the idea of using a standard.
> Have a nice weekend,
> Baudson Christoph
> http://www.wheregroup.com
Christoph Ratke
Geoinformationsdienst GmbH
Götzenbreite 10, 37124 Rosdorf
Geschäftsführer: Dirk Feise
HRB:3062, Amtsgericht Göttingen
Tel.:   ++49 551-7890420
Fax.:   ++49 551-7890429
Email: ratke at geoinformationsdienst.de
Web: http://www.geoinformationsdienst.de
More information about the Mapbender_users mailing list
