Antw: Re: [Mapbender-users] MB 2.4.2 RC - gazetteerWFS
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Fri Jul 20 09:07:09 EDT 2007
Hallo,
das Problem ist inzwischen behoben worden.
the problem has been solved.
http://trac.osgeo.org/mapbender/ticket/72
Christoph Ratke schrieb:
> Helas all,
> I am using the gazetteer as well and it is working fine - with Firefox.
> Using IE I also have an empty iframe. The IE Error console tells me that
> a "unbekannter Laufzeitfehler" (unknown runtime error?) in module
> mod_wfs_gazetteer_client occurrs. In FF the javascript console is empty.
> Does anybody have an idea?
> @ Ronald: which browser(s) are you using?
> Christoph Ratke
> Am Freitag, den 20.07.2007, 10:34 +0200 schrieb Ronald Woita:
>> Hi,
>> The wfs_conf id is correctly inserted in the element_var 'wfsConfIdString' and there is'nt an error message in mapbender_log anymore, but the iframe is still blank.
>> Looking at the following source text from my GUI I wonder about the line
>> -->var targetString = 'mapframe1,overview';var wfsConfIdString = '';<--
>> Why is'nt there a value for wfsConfIdString although the same string in comment is correct ?
>> greetings
>> Ronald
>> <script type="text/javascript">
>> var wfsConfIdString = '11';
>> </script>
>> <style id="wfsConfStyle" type="text/css"></style>
>> var targetArray = targetString.split(",");
>> var global_wfsConfObj;
>> var global_selectedWfsConfId;
>> var point_px = 10;
>> var resultGeom = null;
>> var cw_fillcolor = "#cc33cc";
>> Ronald Woita
>> http://geoportal.rostock.de
>> Hansestadt Rostock
>> Kataster-, Vermessungs- und Liegenschaftsamt
>> Holbeinplatz 14, 18069 Rostock
>> email: ronald.woita at rostock.de
>> phone: +49 (0)381 - 381 6256
>>>>> verena.diewald at wheregroup.com 19.07.2007 08:53 >>>
>> Ronald Woita schrieb:
>>> Hi all,
>>> in previous version 2.4.1 I used the module '../php/mod_wfs_gazetteer.php'.
>>> In version 2.4.2 this was replaced by '../javascripts/mod_wfs_gazetteer_client.php'.
>>> I tried to configure it with the same WFS settings, but I get an empty iframe for the gazetteerWFS and this error message in log :
>>> 2007.07.19, 07:59:44,Error while executing prepared statement in /srv/www/htdocs/mapbender/geoport_242/http/php/mod_wfs_gazetteer.php: Sql: SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2, Error: ERROR:  invalid input syntax for integer: ""
>>> Are there any additional modules to load in the gui (excepting ajax)?
>>> greetings
>>> Ronald
>>> Ronald Woita
>>> Hansestadt Rostock
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Hi Ronald,
>> as Mapbender uses now ajax for wfs gazetteer, wfs_conf IDs are now
>> inserted comma separated in Element Var named "wfsConfIdString", not
>> longer in src url. This could be the problem why you get the empty
>> iframe. To get more information you can also have a look to Mapbender Wiki:
>> http://www.mapbender.org/index.php/WFS_gazetteer#Element_vars
>> Best regards
>> Verena
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_users mailing list
