[Mapbender-users] inconsistencies in mapbender-DB?
Marco Lechner marco.lechner at geographie.uni-freiburg.de
Fri Jun 29 03:27:04 EDT 2007
Hallo list,
last week we moved our postgreSQL/postgis DBs to a new machine including
a software upgrade. Therefore it was necessary to dump our included
mapbender-Installations. We went into trouble, because the
postgis-specific scripts need a errorfree database. Trying to restore
our mapbender-dumps we ran into a few foreign-key-constraints-errors
(the fkc could not be restored) caused by records existing in the tables
that are related to records from parent tables that are not existing any
more. As an example: there are records in the layer_epsg table which are
missing there accoring recordset in the layer-table. Those
inconsistencies were there from the original installation and not caused
by our own entries.
Why are those records existing? Shouldn't the database be cleaned?
We created a little SQL-script cleaning our Mapbender-database before
dumping and and were able to restore this dump without problems. We are
not sure, if this script can be used universal, but it worked for us.
May be someone can proof it and use it to clean his/her installation. Or
one of the developers (following this list) could proof if they can use
the script to clean the initial-mapbenderdatabase for further releases.
Marco
-- Script cleans Mapbender 2.4.1 installations from spurious and
obsolete data
-- Marco Lechner und Steffen Vogt, 2007-06-08, Physical Geography, Uni
Freiburg
DELETE FROM layer WHERE NOT EXISTS (SELECT * FROM wms WHERE
layer.fkey_wms_id = wms.wms_id);
DELETE FROM layer_epsg WHERE NOT EXISTS (SELECT * FROM layer WHERE
layer_epsg.fkey_layer_id = layer.layer_id);
DELETE FROM gui_element_vars WHERE NOT EXISTS (SELECT * FROM gui_element
WHERE (gui_element_vars.fkey_gui_id = gui_element.fkey_gui_id) AND
(gui_element_vars.fkey_e_id = gui_element.e_id ));
DELETE FROM layer_style WHERE NOT EXISTS (SELECT * FROM layer WHERE
layer_style.fkey_layer_id = layer.layer_id);
DELETE FROM gui_layer WHERE NOT EXISTS (SELECT * FROM layer WHERE
gui_layer.fkey_layer_id = layer.layer_id);
DELETE FROM wms_format WHERE NOT EXISTS (SELECT * FROM wms WHERE
wms_format.fkey_wms_id = wms.wms_id);
DELETE FROM wms_srs WHERE NOT EXISTS (SELECT * FROM wms WHERE
wms_srs.fkey_wms_id = wms.wms_id);
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20070629/8998aa2d/marco.lechner.vcf
More information about the Mapbender_users mailing list
