[Mapbender-users] Funcionality Opacity: modifications of mapbender files to change opacity image
Emilio Pardo emilio.pardo.ext at juntadeandalucia.es
Thu Mar 15 04:09:15 EDT 2007
Hallo
Another day I did a question about  the possibility of mody the opacity
of the different images when you connect with more than one wms server.
The response was that was not implemented.
 A good friend (Virgilio Rey)  has done the code modifications to have
this functionality,
 It is necessary to modify three files
                        Map.php
                        Map_obj.js
                        mod_WMSpreferences.php
CHANGES IN MAP.PHP
/*Change to Opacity*/
/* [VRL 14/03/07] leemos el valor de mb_mapObj[i].gui_wms_mapopacity y
lo asignamos al estilo en distintos formatos */
 cadenaOpacity = "opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity+";
Filter: Alpha(Opacity="+mb_mapObj[i].wms[ii].gui_wms_mapopacity*100+");
-moz-opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity+" ;
-khtml-opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity;
 newMapRequest += "<div id='"+myDivId+"' style=\"position:absolute;
top:0px; left:0px; z-index:'"+ii+"';"+cadenaOpacity+"\">";
/*End Change to Opacity*/
ORIGINAL
newMapRequest += "<div id='"+myDivId+"' style='position:absolute;
top:0px; left:0px; z-index:"+ii+"; '>";
CHANGES IN MAP_OBJ.JS
/* [VRL 14/03/07] definimos gui_wms_mapopacity inicializado a 1 */
                this.gui_wms_mapopacity = 1 ;
/* End Change to Opacity*/
Include this line in at the end pf function wms_const
 CHANGES IN MOD_WMSPREFERENCES.PHP
Add these functions
   Hay que buscar donde se define mb_mapObj[] y añadirle el valor
gui_wms_mapopacity
   que será donde se guarde el valor de la opacidad. [Se se puede poner
el valor 1 mejor]
   Por otro lado, en el "map" hay que leer ese valor de
gui_wms_mapopacity y asignárselo al "opacity: "
function setMapOpacity(val){
                var tmp = val.split(",");
                my.wms[tmp[0]].gui_wms_mapopacity = tmp[1];
                loadWMS();
function cambia_opacity(id,incremento)
    objeto = opener.mapframe1.document.getElementById('div_'+id);
    opacity = objeto.style.opacity*100 - (-incremento);
    opacity = (opacity < 100)? ((opacity > 0)? opacity : 0) : 100;
   objeto.style.opacity = (opacity / 100);
   objeto.style.MozOpacity = (opacity / 100);
   objeto.style.KhtmlOpacity = (opacity / 100);
   objeto.style.filter = "alpha(opacity=" + opacity + ")";
   setMapOpacity(id+","+(opacity / 100));
Change the table  and include one row
                               /* [VRL 13/03/07] Modificado para leer el
valor de la opacity almacenado en gui_wms_mapopacity */
                               str += "<tr><td>Cambiar
Opacidad:</td><td><input type=\"button\"
onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','-10')\"
value=\"-\">";
                               str += "<input
id=\"valor_opacity_"+visibleWmsIndexArray[i]+"\" type=\"text\"
disabled=\"disabled\" size=\"3\"
value=\""+my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100+" %\">";
                               str += "<input type=\"button\"
onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','+10')\"
value=\"+\">";
                               str += "</td></tr>";
Sorry but the coment of the autor is in Spanish
These changes have been realized to the version  Mapbender 2.4.0 I do
not believe that there are problems with the new version 2.4.1
 If some one need the files I´ll send by mail.
Skipped content of type multipart/related
More information about the Mapbender_users mailing list
