[Mapbender-users] problems with digitize GUI with geoserver as WFS
Arnulf Christl arnulf.christl at wheregroup.com
Thu Mar 22 04:57:11 EDT 2007
Christoph Baudson (WhereGroup) wrote:
> Hi Marco,
> thanks for your mail. I'm sure it's a configuration issue.
> Did you try to feed the WFS-Request to GeoServer directly? Do you get an
> error message? Another way is to throw an exception in geom2wfst.php:
> Just add another line at line number 106
> $e = new mb_exception('WFS result: '.$data);
> Cheers,
> Christoph
my 2ct are to have a look into the architecture. Is the corresponding
Mapbender service allowed to access the internet? You are using
wms1.ccgis.de as the WFS-T so your Mapbender scripts must be allowed
into the internet, maybe you have to configure a proxy in mapbender.conf
to be able to do this. Then we could also check whether our WFS modules
are all correctly implemented to use these proxy settings.
The main problem is that there are only very few WFS-T out there and
practically not one of them is open to write back, not even
OpenStreetMap operates one although they have a clear focus on free data.
Best regards,
Arnulf.
> Marco Lechner schrieb:
>> Hallo Mapbender-User,
>> I started a little Mapbender-Installation using Version 2.4.1
>> (2007-03-12) (svn)
>> Created a nice GUI using the digitize GUI as template. I want to write
>> some polygons via geoserver into a postgis-DB.
>> But I just get the message "An error occured" while trying to save the
>> polygon to the wfs in mapbender.
>> Having a look to the apache-log it looks o.k.:
>> ..."POST /chennai/mapbender_svn/extensions/geom2wfst.php HTTP/1.1" 200 20
>> and also the transmitted values seem to be valid:
>> ... <wfs:Transaction version="1.0.0" service="WFS"
>> xmlns="http://www.someserver.com/myns"
>> xmlns:chennai="http://www.geographie.uni-freiburg.de:7080/geoserver/wfs?"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xs="http://www.w3.org/2001/XMLSchema"
>> xmlns:citef="http://www.opengis.net/cite/functions"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:topp="http://www.someserver.com/topp"
>> xmlns:wfs="http://www.opengis.net/wfs"
>> xsi:schemaLocation="http://www.someserver.com/myns
>> http://wms1.ccgis.de/geoserver-1.3-beta4/wfs/getCapabilities?request=describefeaturetype
>> http://www.opengis.net/wfs../wfs/1.0.0/WFS-transaction.xsd"><wfs:UpdatetypeName="chennai:floods"><wfs:Property><wfs:Name>notes</wfs:Name><wfs:Value>blablub</wfs:Value></wfs:Property><wfs:Property><wfs:Name>year</wfs:Name><wfs:Value>1998</wfs:Value></wfs:Property><wfs:Property><wfs:Name>the_geom</wfs:Name><wfs:Value><gml:MultiPolygon
>> srsName="EPSG:4326"><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>80.234,12.971
>> 80.241,12.964 80.253,12.976
>> 80.234,12.971</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></wfs:Value></wfs:Property><ogc:Filter><ogc:FeatureId
>> fid="false"/></ogc:Filter></wfs:Update></wfs:Transaction>
>> I'm trying to find the bug (misconfiguration in mapbender because I
>> can edit the relevant WFS-layer using  udig without any problems.
>> Where could there be misconfiguration? What could I try next?
>> Marco
>> Department of Physical Geography
>> Werderring 4
>> 79085 Freiburg
>> 0761/203-3548
>> Germany
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Baudson Christoph
> http://www.wheregroup.com
More information about the Mapbender_users mailing list
