[Mapbender-users] MB leaves garbage in various tables
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Nov 14 10:38:09 EST 2007
Ronald Woita schrieb:
> Hi all,
> after upgrading a mapbender installation from 2.4.1 to 2.4.3 I toyed
> with WMS administration.
> (insert, delete and update wms)
> There I experienced that MB leaves garbage in various tables;
> e.g. deleting a wms from administration :
> in the following tables the correspondending entries won't delete :
> wms_format, wms_srs, gui_layer
> And after running the script 'set_serial_sequences.sql' I can't do
> anything else in the admin-guis, because I always run into 'pk-violate'
> errors.
> I checked the DB concerning the primery keys from 2.4.1-update script,
> but that's all correct ?!
> any hints welcome,
> Regards
> Ronald
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Hello,
have a look at http://www.mapbender.org/index.php/Database-cleaning-script
http://www.mapbender.org/index.php/Template:Changelog_2.4.2
There is a database-cleaning-script. Maybe this will solve the problem.
Greetings from Bonn
Astrid
More information about the Mapbender_users mailing list
