Antwort: [Mapbender-users] Problem emit WMS service of the LDS NRW
Armin Retterath armin.retterath at lvermgeo.rlp.de
Fri Sep 7 03:18:38 EDT 2007
Hello,
you can test it although in http://www.geoportal.rlp.de . There you have
a mapbender implementation where the server is positioned to load
capabilities from different networks (rlp-net, kommunal-net-rp, www).
I've stored a wmc document where you can see the photos from nrw and rp
together. You don't need to register - the document is stored by user
guest (default). Simply open the wmc called 'testluftbildnrw'.
armin
Am Freitag, den 07.09.2007, 08:50 +0200 schrieb
Gunter.Rieth at stadt.mainz.de:
> Hi,
> I think that the service runs OK.
> I tried it with MapInfo as  WMS - Client and works fine.
> http://www.gis2.nrw.de/wmsconnector/wms/luftbild?REQUEST=GetCapabilities&VERSION=1.1.0&SERVICE=WMS
> Mit freundlichen Grüßen
> i. A.
> Gunter Rieth
> Kommunale Datenzentrale Mainz
> -Eigenbetrieb der Stadt Mainz-
> Hechtsheimer Straße 31a
> 55131 Mainz
> URL: http://www.kdz.mainz.de
> Tel.:  06131/12-1629
> Fax.:  06131/12-1603
> eMail:gunter.rieth at stadt.mainz.de
> "Ralf Eckert" <ralf.eckert at stadt-gummersbach.de>
> Gesendet von: mapbender_users-bounces at lists.osgeo.org
> 07.09.2007 08:35
> Bitte antworten an
> Mapbender User List <mapbender_users at lists.osgeo.org>
> An
> Kopie
> Thema
> Hello list,
> with the attempt WMS of services of the LDS
> http://www.geoserver.nrw.de/home/gbdatenLDS.html
> to load into the MapBender.
> for example:
> After a longer running time I receive the following error messages:
> file:
> Warning:
> file_get_contents
> failed tons of open stream: Connection timed out in
> /nas1/htdocs/mapbender223intra/http/classes/class_connector.php on LINE 49
> Unable ton of open document:
> The attention is probably the Connection timed out!
> With me those are to be gotten warning activated around more information.
> The MapBender runs in the Intranet of the city Gummersbach and is to
> represent the maps for the internal official use with further
> specialized's applications.
> Do other problems similar of you have? If not, where my error lies, how I
> eliminate it?
> MfG
> i.A. Ralf Eckert
> Stadt Gummersbach
> Fachbereich 9
> GIS - Koordination
> Rathausplatz 1
> 51643 Gummersbach
> Tel:  (49) 2261 / 87 - 1318
> Fax:  (49) 2261 / 87 - 8318
> Web:  www.gummersbach.de
>       gis.gummersbach.de
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Armin Retterath
Kompetenz- und Geschäftsstelle
Geodateninfrastruktur Rheinland-Pfalz
beim LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon: +49 (0)261/492-466
Fax: +49 (0)261/492-492
E-Mail: armin.retterath at lvermgeo.rlp.de
More information about the Mapbender_users mailing list
