[Mapbender-users] Problems with load WMC when using treeConfGDE
Roland Jehle r.jehle at ceit.at
Thu Sep 13 08:22:31 EDT 2007
Cheers!
I'm using the Module "treeConfGDE" with mod_treefolderClient.php  and
GUI2 with just 1 WMS (Demis World Map) in it.
When I load a previously saved WMC I always get the same error message:
"t has no properties" . The Tree is not working after this any more.
I tried to debug and found out in map.js the var
wmsInd=getWMSIndexById(fname,wms_id) is undefined after loading the WMC.
Actually the input variables (fname,wms_id) to this function are the
same like in the initialisation of the GUI..
If I set wmsInd=0 it works properly but I want to use it finally with
more than 1 WMS.
Hope somebody has an idea.
Thanks a lot!
Roland
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20070913/468a4f51/attachment.html
More information about the Mapbender_users mailing list
