[Mapbender-users] Problems with load WMC when using treeConfGDE
Roland Jehle r.jehle at ceit.at
Fri Sep 14 03:52:48 EDT 2007
Hi Christoph,
Thanks very much for your informations §:->. I checked all the links you
sent but actually didn't know whether the problems are solved yet and how to
force a solution.
It seems that that my problem is a general problem if somebody tries to use
the treeConfGDE in connection with saveWMC an.
With the other kind of trees this problem isn't there.
I think it would be a good "enhancement" in the Mapbender evolution to fix
this problem. I will insert a new ticket.
Lg
Roland
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org
[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Christoph
Baudson
Gesendet: Freitag, 14. September 2007 08:22
An: mapbender_users at lists.osgeo.org
Betreff: Re: [Mapbender-users] Problems with load WMC when using treeConfGDE
Hi Roland,
it might be that treeConfGDE and WMC have a compatibility problem. A WMC
can only handle WMS with depth 1. This may cause the problem. There is no
solution to this I know of.
To show you how the information about Mapbender is organized, please allow
me to illustrate how it can be found in this case:
1) www.mapbender.org "Modules and API"
(http://www.mapbender.org/index.php/Modules)
2) look up the module that fails (LoadWMC,
http://www.mapbender.org/index.php/LoadWMC)
3) check "known issues"
(http://www.mapbender.org/index.php/LoadWMC#known_issues), follow the link
to Trac (http://trac.osgeo.org/mapbender/report/17)
4) There is a ticket #2 (load WMC fails with deeply nested wms/layer). If
the problem was solved, you would find all necessary information there.
If you were interested in an enhancement that enabled treeConfGDE and WMC
to work together, you would insert a new ticket (register first here
https://www.osgeo.org/cgi-bin/ldap_create_user.py) with type
"enhancement", and describe what you want. Other users can now find this
enhancement ticket (feature request) and might join the development or
funding.
Thanks,
Christoph
On Thu, September 13, 2007 2:22 pm, Roland Jehle wrote:
> Cheers!
> I'm using the Module "treeConfGDE" with mod_treefolderClient.php  and
> GUI2 with just 1 WMS (Demis World Map) in it.
> When I load a previously saved WMC I always get the same error message:
> "t has no properties" . The Tree is not working after this any more.
> I tried to debug and found out in map.js the var
> wmsInd=getWMSIndexById(fname,wms_id) is undefined after loading the WMC.
> Actually the input variables (fname,wms_id) to this function are the
> same like in the initialisation of the GUI..
> If I set wmsInd=0 it works properly but I want to use it finally with
> more than 1 WMS.
> Hope somebody has an idea.
> Thanks a lot!
> Roland
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users mailing list
