[Mapbender-users] sel_area box hidden behind map images
Michael Schulz mschulz at webgis.de
Wed Sep 19 05:24:08 EDT 2007
Hi Christoph,
yes, I will create a ticket. I was just wondering that no one else had
this problem. Maybe someone could try to reproduce this effect.
http://trac.osgeo.org/mapbender/ticket/99
Cheers, Michael
2007/9/19, Christoph Baudson (WhereGroup) <christoph.baudson at wheregroup.com>:
> Michael,
> as this seems to be a bug, would you please file a trac ticket and check
> in the modified file? This way I'm able to add this bug fix to MB 2.4.3.
> Da es sich wohl um einen Fehler handelt, könntest Du bitte ein Trac
> Ticket eintragen und die modifizierte Datei einchecken? Dann kann es
> noch in MB 2.4.3 einfliessen.
> Thanks
> Christoph
> Michael Schulz schrieb:
> > Hi Marc,
> > i was also looking through the different references on z-indexes and
> > finally came to the conclusion that the crucial point seems to be the
> > stacking context, that states that elements with z-indexes are stacked
> > in a context, in a way that if  parent element has a z-index, and
> > child elements have z-indexes, the children stay inside the stacking
> > context and do not overlap with other stacking contexts. I then
> > checked mod_map1.php and found, that the parent map div has no z_index
> > defined, thus the map images inside it inherit the document stack
> > context and hence collide with other z-indexes. Simply adding a
> > z-index:2 at the map-div solved the problem. No other z-index had to
> > be touched.
> > I tried this first (changing only the z-indexes of the red lines), but
> > uh, suddenly the measure module was affected, not good.
> WhereGroup GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 17
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:info at wheregroup.com
> http://www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
> Baudson Christoph
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
+++ INTERGEO 25.09. - 27.09.07 Leipzig - Open Source Park, Halle 3,
Stand K3.302 +++
More information about the Mapbender_users mailing list
