[Mapbender-users] limitation in wfs search?
Christoph Ratke ratke at geoinformationsdienst.de
Fri Sep 21 08:42:08 EDT 2007
Hi Michael,
I am not sure which xml source you mean. Do you mean the filter
generated by the mod_wfs_gazetteer_server.php? Or the WFS getFeature
result? They both seem to be looking fine. I tested the getFeature XML
result with validator and got no error.
Am Freitag, den 21.09.2007, 13:48 +0200 schrieb Michael Schulz:
> Hi Christoph,
> could you have a look at the xml source you're getting back from the
> mapbender wfs-gazetteer? Especially search for extra characters, that
> should not be there (e.g. in tags). I had wfs-gazetteer result
> problems in the last days also and my problem was that the xml parser
> choked on the xml, because the transfer was corrupted.
> Cheers, Michael
> 2007/9/21, Christoph Ratke <ratke at geoinformationsdienst.de>:
> > Hi list,
> > I wonder if there is kind of a limitation of search results or a timeout
> > in the wfs gazetteer module. But I cannot find anything.
> > I am testing a gazetteer where I am trying to get more than about 1000
> > rows but I always get 'No result'. Submitting the WFS request directly
> > with a browser I get a proper result. If I restrict the query further
> > everything is working fine in mapbender, too.
> > Do you have any ideas?
> > Christoph Ratke
> > Christoph Ratke
> > Geoinformationsdienst GmbH
> > Götzenbreite 10, 37124 Rosdorf
> > Geschäftsführer: Dirk Feise
> > HRB:3062, Amtsgericht Göttingen
> > Tel.:   ++49 551-7890420
> > Fax.:   ++49 551-7890429
> > Email: ratke at geoinformationsdienst.de
> > Web: http://www.geoinformationsdienst.de
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
Christoph Ratke
More information about the Mapbender_users mailing list
