[Mapbender-users] limitation in wfs search?
Michael Schulz mschulz at webgis.de
Fri Sep 21 08:55:37 EDT 2007
Hi Christoh,
I meant the WFS getfeature result. If this is ok, then maybe try
changing the way you connect to the service, via the CONNECTION
parameter in mapbender.conf.
Cheers, Michael
2007/9/21, Christoph Ratke <ratke at geoinformationsdienst.de>:
> Hi Michael,
> I am not sure which xml source you mean. Do you mean the filter
> generated by the mod_wfs_gazetteer_server.php? Or the WFS getFeature
> result? They both seem to be looking fine. I tested the getFeature XML
> result with validator and got no error.
> Am Freitag, den 21.09.2007, 13:48 +0200 schrieb Michael Schulz:
> > Hi Christoph,
> > could you have a look at the xml source you're getting back from the
> > mapbender wfs-gazetteer? Especially search for extra characters, that
> > should not be there (e.g. in tags). I had wfs-gazetteer result
> > problems in the last days also and my problem was that the xml parser
> > choked on the xml, because the transfer was corrupted.
> > Cheers, Michael
> > > Hi list,
> > > I wonder if there is kind of a limitation of search results or a timeout
> > > in the wfs gazetteer module. But I cannot find anything.
> > > I am testing a gazetteer where I am trying to get more than about 1000
> > > rows but I always get 'No result'. Submitting the WFS request directly
> > > with a browser I get a proper result. If I restrict the query further
> > > everything is working fine in mapbender, too.
> > > Do you have any ideas?
> > > Christoph Ratke
> > > Christoph Ratke
> > > Geoinformationsdienst GmbH
> > > Götzenbreite 10, 37124 Rosdorf
> > > Geschäftsführer: Dirk Feise
> > > HRB:3062, Amtsgericht Göttingen
> > > Tel.:   ++49 551-7890420
> > > Fax.:   ++49 551-7890429
> > > Email: ratke at geoinformationsdienst.de
> > > Web: http://www.geoinformationsdienst.de
> > > _______________________________________________
> > > Mapbender_users mailing list
> > > Mapbender_users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Christoph Ratke
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
+++ INTERGEO 25.09. - 27.09.07 Leipzig - Open Source Park, Halle 3,
Stand K3.302 +++
More information about the Mapbender_users mailing list
