AW: [Mapbender-users] Geoserver Default WFS Capabilities into Map bender
"Weißmann, Markus" Markus.Weissmann at LGN.Niedersachsen.de
Fri Sep 28 03:33:45 EDT 2007
Hello Roland!
at WFS Conf the default WFS from Geoserver appear with "Compumatica Secure
Networks - We secure YOUR business", but but there is not any layer to
select or configure.
Markus
  _____
Von: mapbender_users-bounces at lists.osgeo.org
[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Roland Jehle
Gesendet: Freitag, 28. September 2007 09:09
An: 'Mapbender User List'
Betreff: AW: [Mapbender-users] Geoserver Default WFS Capabilities into
Hello Makus!
It is difficult for me to find out your problem, but with Geoserver normally
it works fine.
Try to find your WFS-Service in the WFS Conf.
If your upload was "ok" you find your WFS in this module and you can
configure it here for your WFS-Search or Digitize.
Lg
Roland
  _____
[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von "Weißmann,
Markus"
Gesendet: Freitag, 28. September 2007 06:59
An: mapbender_users at lists.osgeo.org
Betreff: [Mapbender-users] Geoserver Default WFS Capabilities into Mapbender
En:
Hello!
For a short time i have got the Geoserver running. The request
<http://%3cserver%3e:8080/geoserver/wfs?REQUEST=getCapabilities&VERSION=1.0.
0&SERVICE=WFS>
http://<server>:8080/geoserver/wfs?REQUEST=getCapabilities&VERSION=1.0.0&SER
VICE=WFS work without any fault. I try to put it into the gui_digitize at
Mapbender with "Load WFS", but unfortunately it does not work. There is no
exception, but i don't see any content. Maybe only a beginner fault. Does
anybody know which one? Other WFS (UMN) work.
Hallo,
De:
Ich habe seit kurzem einen Geoserver am Laufen. Der Aufruf des Default-WFS
0&SERVICE=WFS>
VICE=WFS funktioniert ohne Probleme. Versuche ich mit "WFS laden" ihn in die
gui_digitize von Mapbender zu laden, klappt es leider nicht. Es gibt zwar
keine Fehlermeldung, aber sehe auch keinen Inhalt. Wahrscheinlich nur ein
Anfängerfehler. Weiß  jemand welcher? Andere WFS (UMN) funktionieren.
Mit freundlichem Gruß
Markus Weißmann
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20070928/1fafc485/attachment-0001.html
More information about the Mapbender_users mailing list
