[Mapbender-users] SLD Editor writes not working SLD URLs
Michael Schulz mschulz at webgis.de
Fri Sep 28 07:02:36 EDT 2007
Hi Roland,
yes, unfortunately this is true at the moment. the layer slds are
saved in the db, but the call to the php function is not implemented.
We are planning to release the complete sld integration with the
upcoming Mapbender 2.5 release in december.
You can try a workaround though ... Donwload the sld-editor zip file
from the wiki page:
http://www.mapbender.org/index.php/SLD#how_do_we_start.3F
You'll find a sld_maprequest.php script, that you can incorporate as
an iframe module "sld_maprequest", that will add the sld parameter as
a vendor specific parameter, with the correct url to the
sld_function_handler script.
BTW, the usage of a static sld file versus a call to a php function,
that creates the sld dynamically is still in discussion. Feel free to
step in.
I tend to the static version, so you don't have to assenble the sld on
each maprequest, but the static version will raise other issues, e.g.
naming conventions ...
Cheers, Michael
2007/9/28, Roland Jehle <r.jehle at ceit.at>:
> Hi Michael,
> Yes, I downloaded the complete SLD-mapbender from the branch!
> Am I right that in this release it is not possible to save a SLD in the DB
> and see my changes in the previewed map?
> ..and I can just use an SLD-XML-File (not in DB) which I refer to in the
> gui-wms settings. So all changes made with the SLD-Editor I have to make
> manually in this .xml!?
> Finally my task is to integrate the SLD-Editor in the WebGIS-Client to
> change colors and numbers of classes in demographic layers (municipalities)
> and I'm happy about every tip about doing this.
> Yes, I will post this in future better in the dev-list and hope to give good
> new inputs there.
> Lg
> Roland
> -----Ursprüngliche Nachricht-----
> Von: mapbender_users-bounces at lists.osgeo.org
> [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Michael
> Schulz
> Gesendet: Freitag, 28. September 2007 11:34
> An: Mapbender User List
> Betreff: Re: [Mapbender-users] SLD Editor writes not working SLD URLs
> Hi,
> i assume you are using the sld-branch code? Calling the php-function
> script is currently not implemented. At the moment one way would be to
> save the generated sld in a file and reference it via an url in the
> sld-url filed.
> The way we are heading with the integration of the sld-url doesn't use
> this php-call as a sld-url. We'd rather save a static sld file to the
> file system, the url to this sld will be inserted in your sld-url
> field in the gui-wms settings. A sld for a wms does not necessarily
> need to come from the sld-editor, it could also be a provided as a
> remote sld.
> But we als also still discussing these issues and we are happy about
> new input, either on the list (perhaps better on dev) or on the wiki
> pages.
> Cheers, Michael
> 2007/9/27, Roland Jehle <r.jehle at ceit.at>:
> > Zers aus Ösi!
> > I have integrated the SLD Editor into Mapbender 242.
> > It seems that it works fine with the example WMS. I can edit the Layers
> SLD
> > and save it.
> > I can also see the saved changes in the SLD in table sld_user_layer.
> > The SLD with URL
> (http://.........../sld/sld_function_handler.php?function=getusersld&layer_i
> d=19009&user_id=1)
> > which is at the end of the URL of the getMap-request seems to be right and
> > gives the SLD-XML back when I insert it in the browser (e.g."Bundeslaender
> > 1.000000 7000000.000000 #ffffff #2f4f4f admin_name  arial 2 0.5 0.5
> #000000
> > Bundesländer 7000000.000000 80000000.000000 #000000 #2f4f4f admin_name
> 0.5
> > 0.5 #000000") and the XML is in the source.
> > I can't find out what is the problem with my SLD-URL, but it doesn't work
> in
> > connection with the getMap requests although it seems to be fine.
> > Lg
> > Roland
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel  +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
> +++ INTERGEO 25.09. - 27.09.07 Leipzig - Open Source Park, Halle 3,
> Stand K3.302 +++
Michael Schulz
in medias res
79108 Freiburg
Stand K3.302 +++
More information about the Mapbender_users mailing list
