[Mapbender-users] Printing results in a rogue PDF file
Michael Schulz mschulz at webgis.de
Mon Aug 4 07:17:02 EDT 2008
Hi Ronald,
this is a problem of the i18n mechanism. Did you enable i18n and use
language german?
Please read on here: http://trac.osgeo.org/mapbender/ticket/262 , this
fix code fragment should go into class_locale.php.
Background: the locale also influences the way what decimal point
representation is used. Unfortunately this is a Komma for german, and
so positioning values in the pdf generating code (the underlaying
czpdf lib) produce numeric values with kommas instead of points.
Cheers, Michael
2008/8/4 Ronald Woita <Ronald.Woita at rostock.de>:
> hi list,
> as a result from Mapbender printing I get a rogue pdf-file.
> Acrobat Reader (KPDF in a same manner) comes up with the message :
> 'an error occured while reading the file (110)'. It's the same behavour
> if I download the file or read it
> from local file system.
> I disabled 'unlink' in print.conf and found correct images in the temp
> dir.
> Unfortunately I got no messages in the log files.
> Any hints welcome !
> I run Mapbender version 2.5 RC 5, UTF-8, PostgreSql on SLES 10.
> greets
> Ronald
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
