[Mapbender-users] set logout_location for gui
Marco Lechner marco.lechner at geographie.uni-freiburg.de
Mon Aug 4 16:04:37 EDT 2008
Hi Michael,
go for the long story:
my mapbender installation is running on an alternative port (8081) for
https, because it's a virtual host on a machine already using the
standard 443-https vor it's own https. Because I want a separate
ssl-certificate for my host running the mapbender-Installation (and of
course I'm using ssl for it) I used RewriteRule in apache to put the
virtual host on https://www.host.com:8081. The problem is, that the
logout script (mod_logout.php) doesn't take care of the "https" and
therefore changes the URL to http://www.host.com:8081 which gives a Bad
Request page like when you try e.g.
http://www.geographie.uni-freiburg.de:443
One solution is to tell mapbender the https://host.com:8081 as definite
logout_location (which I still can't find in the GUI (where for *!~%!
can these f... gui_env_vars be set?).
The IMHO better solution (isn't mapbender running most of the time in a
https-mode?) is the little diff I attached which adds an if-clause to
mod_logout.php to evaluate $_SERVER['HTTPS'].
If this is o.k. someone with write-access could add it to the SVN.
Marco
P.S. yeah, found it also in the GUI! I told you - one of those days.
Well, i still like my diff-solution better ;-)
Michael Schulz schrieb:
> Hi Marco,
> setting this gui element var should work definitely through the
> admin_guis. What happens? Is the login screen displayed? Did you check
> the mb error log?
> I just tested it, with success. Did you specify a complete url?
> Cheers, Michael
> Am 4. August 2008 18:12 schrieb Marco Lechner
> <marco.lechner at geographie.uni-freiburg.de>:
>> Hi mapbenders,
>> I try to set the logout_location (gui_element_vars) for one of my guis. Do I
>> have to edit the value in postgresql itself or is the setting of this
>> variable implemented in the mapbender-GUI. Well, I searched for it, but may
>> me today is one of my "blind days".
>> Marco
>> P.S. mapbender 2.5.0 RC5 (11-07-2008)
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080804/fc79465b/mod_logout.php.bin
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080804/fc79465b/marco_lechner.vcf
More information about the Mapbender_users mailing list
