[Mapbender-users] German 'Umlauts' in PDF-Print
Christoph Baudson christoph.baudson at wheregroup.com
Fri Aug 15 09:57:25 EDT 2008
Michael Schulz schrieb:
> Hi Ronald,
> I have filed a ticket concerning a similar problem, that one will face
> when using i18n with printPDF:
> http://trac.osgeo.org/mapbender/ticket/265
> I am not even sure if this is a problem related only to the encoding,
> but maybe also to the font used in pdf printing. If it were "only"
> encoding problems, then we didn't have to use this special character
> array you'll find in mod_printPDF_pdf.php. But I agree, that pdf only
> works with iso-8859-1 characters.
For those who didn't follow the ticket status:
Text strings to be included in the PDF are now utf8_decoded. This is
only a temporary solution, as Mapbender 2.5 only supports english and
german. In the long run, we need a PDF lib that uses an UTF8 font.
http://trac.osgeo.org/mapbender/changeset/2772
This is considered a workaround only.
> Cheers, Michael
> 2008/8/6 Ronald Woita <Ronald.Woita at rostock.de>:
>> Hi Marc,
>> thanks for your reply Marc-
>> 'file printPDF.conf' only delivers this result--> PHP text File,
>> but 'less printPDF.conf' displays correct characters on a bash.
>> But if I convert the string to ISO-8859-1 (see below) everything is fine ?!
>> # labeling
>> if(CHARSET=="UTF-8"){
>>        $new_comment1 = utf8_decode($_REQUEST["comment1"]);
>>        $new_comment2 = utf8_decode($_REQUEST["comment2"]);
>> else{
>>        $new_comment1 = $_REQUEST["comment1"];
>>        $new_comment2 = $_REQUEST["comment2"];
>> $text1 = utf8_decode("GeoPort.HRO");
>> $text2 = utf8_decode"das GeodatenPortal für die";
>> $text3 = utf8_decode"Hansestadt Rostock und Umgebung";
>> $text4 = utf8_decode"";
>> $text5 = utf8_decode("Maßstab ca. 1:"). " ".$_REQUEST["map_scale"];
>> If I understand this in the correct manner, then the pdf class seems to use ISO encoding ?
>> greets
>> Ronald
>>>>> jansen.marc at gmx.de 06.08.2008 10:01 >>>
>> Hi Ronald,
>> when you edited the printPDF.conf, did you save the file UTF8-encoded?
>> What is the output of:
>> file printPDF.conf
>> (on a linux-prompt, assuming your installation is running on a linux system)
>> Have you tried e.g. iconv? (make sure you've got a backup)
>> --Marc
>> Ronald Woita schrieb:
>>> Hi list,
>>> I'm still working on the pdf printing process...
>>> There is text with 'umlauts'  in my printPDF.conf, but these 'umlauts'
>>> does'nt display correct in the pdf-document.
>>> I just tried to replace the 'umlauts' with html notation, but this
>>> does'nt work too.
>>> The whole system enviroment is configured as UTF-8, eg. OS, database,
>>> Apache... so I don't know, what's the cause of it.
>>> Does anybody get an idea, how to solve this issue ?
>>> Mapbender 2.5 rc5
>>> PostgreSql 8.3
>>> UTF-8
>>> greets
>>> Ronald
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
