[Mapbender-users] transfer a variable to mapfile
Aqua Miracle aqua.amiracle at gmail.com
Fri Aug 15 10:15:08 EDT 2008
Hi Christoph,
Thanks for the mail.
I apply variable into my mapfile as below.
  CONNECTIONTYPE postgis
  NAME "test_point"
  CONNECTION "user=postgres password=test dbname=test_db host=localhost"
 DATA "the_geom FROM (SELECT location.the_geom as the_geom, location.date as
date, FROM locationWHERE location.date='%ldate%') as foo using SRID=-1"
What I would like to do is before this WMS display in mapbender, user need
to select "ldate".
Is there any file I can set?
Thanks,
AQ
2008/8/15 Christoph Baudson <christoph.baudson at wheregroup.com>
> Aqua Miracle schrieb:
> Dear all,
>>  I would like to transfer a variable for variable substitution to the
>> umn-mapfile. Is it possible?
>>  Pls. help.
> Hello,
> can you please be more specific? I have no idea what you are trying to do.
> I will help as best as I can as soon as I have understood your problem.
> Thanks
> Christoph
>  Thanks,
>> Aq,
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080815/d158346c/attachment.html
More information about the Mapbender_users mailing list
