[Mapbender-users] MB 2.5: no load of wfs generated by mapserver 5.xx.x possible
Michael Schulz mschulz at webgis.de
Fri Dec 5 08:29:19 EST 2008
sorting is supported from wfs1.1 on. So unfortunately mapbender 2.5
will not be able to use this feature, you'll have to wait for 2.6. But
there is a post from A. Aime stating that:
Output sorting is part of the WFS 1.1 specification, thus we support
it for the WFS 1.1 queries, but only if they are made against a
datastore that has native sorting abilities (for the moment, the DBMS ones).
As a side effect of how we implement things, sorting should be available
on WFS 1.0 as well when using GET requests, for details see the WFS
specification
I haven't tried it, but maybe this helps.
Cheers, Michael
2008/12/5 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
> Hi Michael,
> it's no good idea writing help messages after looking for the error for some time ;-)
> So I just found the error in the select-statement of the DATA-clause (clarifying your tipps).
> WFS generated of mapserver 5.xx.x are also working with MapBender.
> Thanks for your reply.
> By the way:
> In the meantime I installed geoserver 1.7.0 and added the required wfs as a geoserver wfs. Do you know a possibility of sorting the result of a geoserver wfs ?
> Thanks
> Herbert Schoenhammer
> und einen schönen Nikolaus-Abend alle miteinander !!
>>-----Ursprüngliche Nachricht-----
>>Von: mapbender_users-bounces at lists.osgeo.org
>>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>>von Michael Schulz
>>Gesendet: Freitag, 5. Dezember 2008 13:28
>>An: Mapbender User List
>>Betreff: Re: [Mapbender-users] MB 2.5: no load of wfs
>>Hi,
>>- are the featuretype attributes present in the capabilities document
>>at all of your mapserver 5.x service?
>>- did you set "wfs_include_items" "all" in your layer metadata?
>>I am sure that mb 2.5 can load successfully mapserver 5.0.2 wfs
>>services. I am using it without problems as a wfs-gazetteer.
>>Cheers,
>>Michael Schulz
>>> Hi list,
>>> I only want to load a wfs into a gui. But this is not
>>possible under all
>>> circumstances with MB version 2.5.
>>> If the wfs is generated by mapserver version 4.xx.x the wfs
>>is loaded and
>>> all attributes of the wfs are listed. Output is:
>>> version: 1.0.0
>>> title: Bodenrichtwertgebiete
>>> abstract: Stadt Regensburg: Suche nach Bodenrichtwertgebieten
>>> capabilitiesrequest:
>>http://geoportal/cgi-bin/getows?map=/cityportal-maps/rgb_wfs_bo
> denrichtwerte.map&
>>> describefeaturetype:
> denrichtwerte.map&
>>> getfeature:
> denrichtwerte.map&
>>> transaction:
>>>   _____
>>> title: Richtwertgebiete zum Stichtag 31.12.2006
>>> abstract:
>>> srs: epsg:31468
>>> element: msGeometry - GeometryPropertyType
>>> element: oid - string
>>> element: gebiet - string
>>> element: stichtag - string
>>> element: name_such_string - string
>>> namespace: ms - http://mapserver.gis.umn.edu/mapserver
>>> namespace: ogc - http://www.opengis.net/ogc
>>> namespace: xsd - http://www.w3.org/2001/XMLSchema
>>> namespace: xmlns - http://www.w3.org/2001/XMLSchema
>>> namespace: gml - http://www.opengis.net/gml
>>> If the wfs is generated by mapsverer version 5.xx.x ( I have
>>testes 5.0.2
>>> and 5.2.0) the wfs is not loaded correctly by mapbender. The
>>wfs has no
>>> attributes:
>>> version: 1.0.0
>>> title: Adressen in Regensburg
>>> abstract: Adressen im Stadtgebiet Regensburg
>>http://secure1.regensburg.de/cgi-bin/mapserv-502?map=/data-umn/
>>wfs/rgb_wfs_adressen.map&
>>> getfeature:
>>> transaction:
>>>   _____
>>> abstract:
>>> srs: EPSG:31468
>>> I wnat to use mapserver 5.x.x. Has anybody a tipp for me ?
>>> greetings
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>Michael Schulz
>>in medias res
>>Gesellschaft für Informationstechnologie mbH
>>In den Weihermatten 66
>>79108 Freiburg
>>Tel  +49 (0)761 556959-5
>>Fax +49 (0)761 556959-6
>>http://www.webgis.de / http://www.zopecms.de
>>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users mailing list
