[Mapbender-users] Symbology-Problem
Karsten Vennemann karsten at TERRAGIS.NET
Wed Dec 10 12:18:03 EST 2008
Hi there,
I am assuming you are using MapServer and a map file :) . Unfortunately I
couldn't see the examples you tried to post, those are stripped off in
mailing list postings (next time you can try putting them on a web server
and just quote the URLs in your post...) So I might be off with the
following suggestion but (since I couldn't see the examples ) but you can
use the MapServer OFFSET tag (inside your layer style) to determine the
location of your symbol in relation the the real word coordinates: OFFSET
[x][y]
e.g.
STYLE
	SYMBOL "POINT"
	SIZE 16
	COLOR 0 0 0
	OFFSET -16 0
END
see at http://umn.mapserver.ch/MapServer/en/style.htm
Cheers
Karsten
birger.heinss wrote:
> Hi List,
> how can I prepare a point symbol in such a way, that its placement
> coordinate is located at a definite position (for instance at the bottom
> of the symbol and not in the centre). We need a combinations of type
> "ellipse" and "vector".
> regular version:
> needed version:
> The cross illustrates the placement point.
> thanks a lot. best regards
> birger
> Vattenfall Europe Information Services GmbH, Hamburg, Amtsgericht Hamburg
> - HRB 86516
> Vorsitzender des Aufsichtsrates: Dr. Hans-Jürgen Meyer
> Geschäftsführer: Dr. Stefan Keese, Ernst Wudtke
> Diese E-Mail wurde digital signiert.
> Sie koennen anhand der Signatur nachvollziehen, dass die E-Mail wirklich
> von
> Vattenfall stammt und dass deren Inhalt auf dem Transportweg nicht
> manipuliert
> wurde. Weitere Informationen ueber die eingesetzten Signaturen finden Sie
> auf
> unserer Website unter http://www.vattenfall.de/pki.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
View this message in context: http://www.nabble.com/Symbology-Problem-tp20935785p20939766.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
