[Mapbender-users] Problems creating an entry of data-type "date" with wfs and gui-digitize
Schönhammer, Herbert Schoenhammer.Herbert at Regensburg.de
Thu Jul 3 03:32:21 EDT 2008
Hi list,
I want to use wfs and gui-digitize to digitize some geometry and put some attributes to the geometry. Nearly all things do the correct thing.
But I also want to store data of data-type "date" in the database. And so I have some difficulties.
First of all:
Database is Oracle 9i (german settings like the date-format). In this database i have defined  an attribute "DATUM" with data-type "date".
For creating a WFS-T i use geoserver 1.6.0. The server does what he should do. But I recognized, that in the "FeatureType Editor" the "DATUM"-attribute is shown as a "string"-type.
After loading and configuring this WFS in Mapbender 2.4.4, this attribute is known in mapbender as a "date"-type (I really don't know, how mapbender knows this, because geo serversays, this is a "string"-type !!!)
I use postgres as mapbender database.
The problem in detail:
Entering a date in the format YYYY-MM-DD in the html-template generated by gui-digitize , this date is accepted by geoserver. But the Oracle database is not accepting this format !
Entering the date in the german format DD-MM-YYYY, geoserver recognizes a "Illegal argument exception" and the oracle DB never gets this argument.
I have done some trials with escape-characters (like \), but this had never an effect !
My Questions:
Does anybody know, how mapbender recognizes the correct format "date" for the DATUM attribute ? (Geoserver says, this is a string attribute).
Does mapbender it's own interpretation of an attribute of type "date" ? (So, the solution could be in altering the date-interpretation of the postgres - db or in the source-code of mapbender ??)
I didn't find any possibility to configure the format of "date"-types in geoserver ? If it is possible to configure this item in geoserver, please let me know where !
Or has anybody a solution for this problem ( I think the problem will also occure, if postgres or mysql is used instead of oracle).
Thanks and greetings
from Herbert
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080703/f46fccac/attachment.html
More information about the Mapbender_users mailing list
