[Mapbender-users] Hyperlink files
Michael Schulz mschulz at webgis.de
Thu Jul 10 04:53:04 EDT 2008
I think geoserver as of version 1.6 has a template mechanism that can
be used to provide customized getfeatureinfo results. Thus you could
create a template that has the <a> tag in the template and the href
attribute would be filled when the template is processed (that's how
it's usually done when using mapserver).
Using an onmouseover effect, you would need your data be served as wfs
also from geoserver, then configure the wfs in mapbender using the
useMap module. Thsi let's you easily display text ... directly
displaying images would be harder and would require to tweak the
module.
HTH, Michael
2008/7/10 San_79 <sanmink at hotmail.com>:
> Hi list,
> In ArcGis I have a point shapefile in which I stored the path to some images
> and pdf documents, so that using the hyperlink tool and clicking on the
> features these files open up in a new window. Is there a way to do something
> similar with geoserver/postgis/mapbender?
> I exported the shapefile to postgis and when clicking in the mapbender GUI
> with the feature info tool I see the path as a text but I would like it to
> be a hyperlink...
> ...or even to display the images as a pop-up with a mouseover??
> What is the easyest way? Can someone give me a hint?
> Many thanks in advance!
> Sandra
> View this message in context: http://www.nabble.com/Hyperlink-files-tp18377639p18377639.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
