[Mapbender-users] Hyperlink files
Sandra Mink sanmink at hotmail.com
Fri Jul 11 04:46:57 EDT 2008
Michael and Uwe, many thanks for your help!
I am going to explore the world of templates...
The small preview image is a good idea. I will try to make it!
Sandra
> Date: Fri, 11 Jul 2008 10:33:32 +0200> To: mapbender_users at lists.osgeo.org> Subject: Re: [Mapbender-users] Hyperlink files> From: uwe.seher at googlemail.com> > On Thu, 10 Jul 2008 10:36:54 +0200, San_79 <sanmink at hotmail.com> wrote:> > > Hi list,> > Hi!> > > In ArcGis I have a point shapefile in which I stored the path to some > > images> > and pdf documents, so that using the hyperlink tool and clicking on the> > features these files open up in a new window. Is there a way to do > > something> > similar with geoserver/postgis/mapbender?> > Yes.> > > I exported the shapefile to postgis and when clicking in the mapbender > > GUI> > with the feature info tool I see the path as a text but I would like it > > to> > be a hyperlink...> > You need to create an image tag in your template which has the path as > src-Attribute like this (UMN-Syntax):> > <img src="[PATH_ATTRIBUTE]">> > > > ...or even to display the images as a pop-up with a mouseover??> > I prefer to use a small preview image and open the whole pic with a click > in a new Window. This looks like:> > <a href="[PATH_ATTRIBUTE]" target=_self><img src="[PATH_ATTRIBUTE]" > width="200" heigth="100" alt="[PATH_ATTRIBUTE]"></a>> > > What is the easyest way? Can someone give me a hint?> > s.o.> maybe you have to make some changes to fit this in your sourounding.> > > > Many thanks in advance!> >> > Sandra> > Your welcome> > Uwe> > ----------------------------------------------------------------------------> http://www.gispunkt.de - http://maps.gispunkt.de> ----------------------------------------------------------------------------> _______________________________________________> Mapbender_users mailing list> Mapbender_users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_________________________________________________________________
MSN Noticias
http://noticias.msn.es/comunidad.aspx
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080711/3e7d9506/attachment.html
More information about the Mapbender_users mailing list
