[Mapbender-users] AW: Mapbender_users Digest, Vol 20, Issue 10
porath at web.de porath at web.de
Tue Jul 22 01:42:16 EDT 2008
Hi Albrecht,
you'll find the required php modules in our wiki at http://www.mapbender.org/Installation_de#PHP_Konfiguration . There is a special chapter for version 2.5. Or did you mean the portal function with "basic issue"? In most of our environments mapbender users are created using the admin-GUI and users are not allowed to create accounts themselves.
Regards,
Holger
-----Ursprüngliche Nachricht-----
Von: <Albrecht.Weiser at hzd.hessen.de>
Gesendet: 21.07.08 16:32:02
An: <mapbender_users at lists.osgeo.org>
Betreff: [Mapbender-users] AW: Mapbender_users Digest, Vol 20, Issue 10
Hi Michael,
that worked very well for me, thanks :o). Now i get all frames and
functionalities.
But if that's such a basic issue, somebody should note that in the wiki.
Best wishes
Albrecht
> Date: Mon, 21 Jul 2008 15:08:56 +0200
> From: "Michael Schulz" <mschulz at webgis.de>
> Subject: Re: [Mapbender-users] mapbender installation was not
> 	successful
> To: "Mapbender User List" <mapbender_users at lists.osgeo.org>
> Message-ID:
> 	<e750b12e0807210608j75fb762drec6ce4799c0e658a at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi Albrecht,
> for localization and internalisation issues Mapbender needs the php
> module mbstring enabled (--enable-mbstring). On Windows you should be
> able to enable it be removing the comment of the appropriate dll in
> php.ini.
> In mapbender.conf you have a setting "portal function" (or something
> like that), if that is set to false, users can't register themselves
> at the login screen and you get the cited message.
> HTH, Michael
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
_______________________________________________________________________
EINE FÜR ALLE: die kostenlose WEB.DE-Plattform für Freunde und Deine
Homepage mit eigenem Namen. Jetzt starten! http://unddu.de/?kid=kid@mf2
More information about the Mapbender_users mailing list
