[Mapbender-users] couldn´t connect to postgre
vollbotz volker.emmel at lwk-rlp.de
Wed Jul 23 10:46:38 EDT 2008
hi list,
i couldn´t connect to postgre:
i always got the following error (..mapbender/http/frames/login.php)
Fatal error: Call to undefined function pg_connect() in
/usr/local/fgs/www/htdocs/mapbender/http/php/database-pgsql.php on line 97
>> the error tells me that PostGre wont be connected or wont work !
>> (right?)
file-entries:
- mapbender.conf
        define("SYS_DBTYPE", "pgsql");
        define("DBSERVER", "200.1.X.XX");
        define("PORT", "5432");
        define("DB", "mapbender");
        define("OWNER", "XXXXXXXX");
        define("PW", "XXXXXXX");
        define("MD5", "true");
#include_once("/usr/local/fgs/www/htdocs/mapbender/http/php/database-pgsql.php");
         include_once("../../http/php/database-pgsql.php");
- php.ini
       extension_dir=/usr/local/fgs/www/lib/php5
       extension=plpgsql.so
....apache has been restarted....
>> which entry is wrong or is additional needed ??
plpgsql.so exists in the extensions-path...
or need i a extension=pgsql.so  ???
System:  Suse Linux 10 - FGS - mapbender2.5 - ...
really don´t know.... i thing it couldn´t be a "big" problem, but ...
Thanks a lot...  V°!
View this message in context: http://www.nabble.com/couldn%C2%B4t-connect-to-postgre-tp18612363p18612363.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
