[Mapbender-users] error while performing wfs-t request
Arnulf Christl arnulf.christl at wheregroup.com
Thu Jul 24 10:19:29 EDT 2008
Verena Diewald wrote:
> Hello Albrecht,
> I forwarded your message to the list, because you sent it to my mail address.
> Greetings
> Verena
> ----------  Weitergeleitete Nachricht  ----------
> Betreff: AW: Mapbender_users Digest, Vol 20, Issue 13
> Datum: Donnerstag 24 Juli 2008
> Von: Albrecht.Weiser at hzd.hessen.de
> An: verena.diewald at wheregroup.com
> Hi Verena,
> thanks for answering. Checking my capabilities was of course the first i did.
> epsg 4326 isn't used anywhere. Therefore my question :o/
> I'm using geoserver 1.6.3 with oracle and ArcSDE Backend. Here are the
> capabilities:
> <?xml version="1.0" encoding="UTF-8"?>
> <!DOCTYPE WMT_MS_Capabilities
> SYSTEM "http://localhost:9080/geoserver/schemas/wms/1.1.1/WMS_MS_Capabilities.dtd">
> <WMT_MS_Capabilities version="1.1.1" updateSequence="53">
((I hate this redundant GeoServer posing with endless SRS lists...!))
<snip>
This is where it gets interesting:
>       <SRS>EPSG:42304</SRS>
>       <SRS>EPSG:42303</SRS>
>       <LatLonBoundingBox minx="7.730792251272924" miny="49.389425754740856"
> maxx="10.251024832358658" maxy="51.66073535342488"/>
This is where Mapbender receives the initial bounding box to zoom to.
And it is correctly specified in WGS84 / alias EPSG:4326
If you want another CRS to start with you have to add the corresponding
bounding box to your service.
While you are at is I suggest that you deactivate the full listing of
SRS in GeoServer, it will only mess up your Mapbender database and
produces a lot of noise where it is not necessary.
>       <Layer queryable="1">
>         <Name>ora:FFH_SDO</Name>
>         <Title>FFH_SDO_Type</Title>
>         <Abstract>Generated from geo1mig_oracle</Abstract>
>         <KeywordList>
>           <Keyword>geo1mig_oracle</Keyword>
>           <Keyword>FFH_SDO</Keyword>
>         </KeywordList>
>         <SRS>EPSG:31467</SRS>
You can also remove the WKT definition of the CRSses. I know of no
clients that actually use this information in a useful manner.
>         <!--WKT definition of this CRS:
> PROJCS["DHDN / Gauss-Kruger zone 3",
>   GEOGCS["DHDN",
>     DATUM["Deutsches Hauptdreiecksnetz",
>       SPHEROID["Bessel 1841", 6377397.155, 299.1528128,
> AUTHORITY["EPSG","7004"]],
Here you have additional CRS bounding box information. But it is only on
the layer level and tehrefore is not recognized by Mapbender as a valid
start box.
>         <LatLonBoundingBox minx="7.732612657295499" miny="49.389425754740856"
> maxx="10.251024832358658" maxy="51.653476119512625"/>
>         <BoundingBox SRS="EPSG:31467" minx="3408063.8953634086"
> miny="5472500.853254962" maxx="3590898.4424268706" maxy="5725107.38517785"/>
>         <Style>
<snip>
Best regards,
Arnulf.
> I grep'd the doc nothing about 4326 (except of the list of available srs).
> It's strange. Also the caps of the wfs doesn't contain 4326.
> The error itself isn't printed in the log files. I'm assuming it's a
> JS-messagebox.
> Hope you have an idea... :o/
> Thanks & best wishes
> Albrecht
>> Hello Albrecht,
>> please check your capabilities document and have a look which
>> EPSGs are
>> mentioned there. Mapbender does indeed get the information
>> like SRS out of
>> the capabilities doc, so I really can't reproduce why that
>> error occurs with
>> the EPSG:4326 in the "Edit GUI_WMS" module. I never had any problems
>> concerning this point.
>> If possible you could post the XML here so everyone can have
>> a look at it. And
>> which GeoServer version do you use?
>> Greetings
>> Verena
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
