[Mapbender-users] MB 2.5rc2: internationalizd module "tabs"
Michael Schulz mschulz at webgis.de
Wed Jun 4 04:12:35 EDT 2008
the tabs module now uses the Title (e_title) field of the
corresponding gui_element that is defined tab_ids array. If the title
field should be used internationalized it must be set to a value that
is translated in the translations table, e.g. for treeGDE title is
Maps, if you look in translations table for msg_id Maps you will find
for language de "Karten". If you change the title to something else
than Maps, it will not work anymore, because there is no corresponding
msg_str in translations.
Hope this helps to clarify a bit.
Greetings, Michael Schulz
2008/4/29 "Schönhammer, Herbert" <Schoenhammer.Herbert at regensburg.de>:
> Hi list,
> I want to get  module tabs working with MB 2.5.rc2.
> This module is not working in the example gui's "gui" and "gui2", which are
> delivered by mapbender 2.5rc2.
> (Firebug says "init is not defined"; don't know which "init")
> There is no tab_titles[] - Array in the element-vars for this module, of
> course. The module should be internationalized.
> But what can I do, to get the "tabs" working ?
> Where/How are the tab_titles now configured in the international context ?
> Only looking at table "translations" isn't really a help for me !
> regards
> Herbert Schoenhammer
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
