[Mapbender-users] How to create a postgres-cluster with encodings UTF-8 and LATIN1 ?
Germán Carrillo carrillo.german at gmail.com
Fri Jun 27 14:39:56 EDT 2008
Hi Herbert, did you read it?
http://www.postgresql.org/docs/8.3/interactive/multibyte.html
Hope it helps you.
Germán Carrillo
2008/6/23 Germán Carrillo <carrillo.german at gmail.com>:
> Hi Herbert, in spanish mailing list Alvaro Herrera says:
> Since PostgreSQL 8.3 there is a change, before 8.3 the server enables you
> to choose a different encoding to regional configuration. This was very
> problematic for the postgres team. For this reason, now you can't combine
> (in only one postmaster) databases with Latin1 and UTF-8.
> The alternative is you choose the C or POSIX regional configuration, which
> can  work with any encoding.
> You can find more information on the postgres mailing list (spanish):
> http://archives.postgresql.org/pgsql-es-ayuda/2008-02/msg00431.php
> I also tried the LATIN1 encoding without any results. If you can resolve it
> please write it.
> Thanks and best regards.
> Germán Carrillo.
> 2008/6/23 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
>> Hi list,
>> Obviously this posting is in the wrong list. But perhaps somebody reading
>> this list has a solution for me. My problems are:
>> I want to create a postgres-cluster, in which it should be possible to
>> generate databases with encodings in
>> - UTF-8 for use as mapbender-db
>> - LATIN1 for storing data in german sort-order and character-set
>> Using postgresql version <= 8.2.x this is no problem. The postgresql does
>> not evaluate the system's LC_CTYPE and so the postgres-user is able to
>> create db's with all wanted encodings.
>> But since postgres 8.3.x the initdb evaluates the system LC_CTYPE (which
>> is set to de_DE.UTF-8). I'm ONLY allowed to generate databases with encoding
>> UTF-8.
>> I have tried using the --locale option of initdb, setting
>> --locale=de_DE.LATIN1. The result is,  I'm only allowed to create databases
>> with encoding LATIN1.
>> Also following the Postgres-doc, i tried --locale=C or --local=POSIX,
>> setting --lc-collate=de_DE.LATIN1: But I'm also only allowd to create
>> databases with encoding UTF-8.
>> Does anybody know, how to specify the initdb options to generate
>> mapbender-db's in UTF-8 and "data"-db's in LATIN1 ?
>> I urgently need some help ;-)
>> Thanks and greetings from
>> Herbert
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>   |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
  |\__
(:>__)(
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20080627/e1f8957b/attachment.html
More information about the Mapbender_users mailing list
