[Mapbender-users] BBOX problem
Michael Schulz mschulz at webgis.de
Thu May 8 18:16:20 EDT 2008
Hi Victor,
in order to start a gui with a certain bbox (different from the extent
of the first wms in the gui, that's the default extent) you need the
additional starturl parameter mb_myBBOX=xmin,ymin,xmax,ymax and you
need to activate the module set_bbox1 for this gui.
HTH, Michael
2008/5/8 Victor Moral <vmoral at fundacionchile.cl>:
> Hi there!
> i'm working on my first deployment of mapbender over mapserver/postgis.
> Everything works great and i'm getting a superb performance from mapbender.
> The only problem i got is trying to set the initial BBOX for mapbender
> after the login. I've tried everything that i found published about this
> functionality, but i spend too much time without results.
> This test deployment, based on the gui2 shipped example,  is running at :
> http://200.75.22.90/mapbender/frames/login.php?name=toresa&password=toresalink
> I need MB to start "zoomed at" the "base" layer.
> Any clues?
> Thx !
> vm
> Víctor Moral M.
> Ingeniero de Proyectos
> Area Medio Ambiente y Energía
> Fundación Chile
> Avda. Parque Antonio Rabat Sur 6165 - Vitacura
> Tel: 56-2-2400648
> www.fundacionchile.cl
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
