[Mapbender-users] BBOX problem
Michael Schulz mschulz at webgis.de
Fri May 9 04:14:01 EDT 2008
Hi Victor,
from what i can see in your gui, there is definitely a problem wih
your extent, as when the gui is loaded the first time you can examine
the coordinates and find rather dd units looking values of
coordinates, after hitting the zoomtofullextent button you find more
utm looking coordinates. At the moment i have no clue, could you try
to disable the module set_Background as it looks you're not using it.
Did you set a min/maxscale for the gui with the setScaleHint module?
If so, please disable it.
Cheers, Michael
2008/5/9 Victor Moral <vmoral at fundacionchile.cl>:
> Thx for your answer Michael!
> but....
> - The "base" layer is the first on the gui (with id 0) but it doesn't
> start  within this extent
> - I've had also tried including
> "mb_myBBOX=160016,6708673,666976,7226699" in the url without results.
> - The element set_BBOX is also activated in the GUI.
> What is missing? Do you want to log into the admin gui?
> vm
> Víctor Moral M.
> Ingeniero de Proyectos
> Area Medio Ambiente y Energía
> Fundación Chile
> Avda. Parque Antonio Rabat Sur 6165 - Vitacura
> Tel: 56-2-2400648
> www.fundacionchile.cl
> Michael Schulz wrote:
>> Hi Victor,
>> in order to start a gui with a certain bbox (different from the extent
>> of the first wms in the gui, that's the default extent) you need the
>> additional starturl parameter mb_myBBOX=xmin,ymin,xmax,ymax and you
>> need to activate the module set_bbox1 for this gui.
>> HTH, Michael
>> 2008/5/8 Victor Moral <vmoral at fundacionchile.cl>:
>>> Hi there!
>>> i'm working on my first deployment of mapbender over mapserver/postgis.
>>> Everything works great and i'm getting a superb performance from mapbender.
>>> The only problem i got is trying to set the initial BBOX for mapbender
>>> after the login. I've tried everything that i found published about this
>>> functionality, but i spend too much time without results.
>>> This test deployment, based on the gui2 shipped example,  is running at :
>>> http://200.75.22.90/mapbender/frames/login.php?name=toresa&password=toresalink
>>> I need MB to start "zoomed at" the "base" layer.
>>> Any clues?
>>> Thx !
>>> vm
>>> Víctor Moral M.
>>> Fundación Chile
>>> Tel: 56-2-2400648
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
