[Mapbender-users] mb_myPOI in Mapbender 2.5 - change in the separator-syntax
Verena Diewald verena.diewald at wheregroup.com
Tue Oct 21 03:27:19 EDT 2008
Hi Sascha,
see http://trac.osgeo.org/mapbender/ticket/299 and
http://trac.osgeo.org/mapbender/changeset/2997 for more information how you
can change back the separator into a "," and why we changed separator ","
to "|". A comma didn't seem to be a good choice of separator at that point
because the user can insert all kind of text into the given textarea of
module MeetingPoint which could easily lead to an error including a comma
into the text string and using it also as separator.
Greetings
Verena
Am Donnerstag 16 Oktober 2008 11:27:31 schrieb Sascha.Tegtmeyer at gv.hamburg.de:
> Hi List,
> with the following type of link you are able to open a Mapbender GUI and
> the the client zooms to a coordinate in the defined scale.
> With the module HighlightPOI and the parameter mb_myPOI the GUI is
> opened and highlights 1 to n pois with a symbol and a special text.
> We discovered a change in the separator-syntax of mb_myPOI from "," to
> "|". Is it possible to switch the separator back to ","?
> Old:
> http://...mb_user_myGui=gui&mb_myPOI2SCALE=<x>,<y>,[scale]&mb_myPOI=<tex
> t>,<x>,<y>
> New:
> t>|<x>|<y>
> Best regards,
> Sascha
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Verena Diewald
Anwendungsentwicklung
Fon: +49 (0)228 / 90 90 38 - 33
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
