[Mapbender-users] Query Parameter for a specific external WMS
Michael Schulz mschulz at webgis.de
Thu Oct 30 09:33:57 EDT 2008
I don't think this is possible at the moment. Mapbender is not aware
of the wms time component. What you could do, is to add the time
parameter as a vendor specific parameter, that would be controlled by
a customized module.
If you want to use the wms time parameter you would also have to setup
your wms accordingly, so that you only have one layer "chlorophyll
measurements" and a time column for your data.
Cheers, Michael
2008/10/30  <gisbert.breitbach at gkss.de>:
> Hello everybody,
> I'm using Mapbender to show different measured raster maps, for example
> Chlorophyll in the north sea measured by satellites. Every day a new
> measurement is done. In my own WMS every new measurement means a new layer
> with a name reflecting the date.
> Other people have solved the problem introducing a time filter parameter
> into the GetMap request like
> ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
> Is it possible to include such a filter parameter into the GetMap request
> of Mapbender and, if yes, how can it be done.
> Many thanks,
> Gisbert Breitbach
> ____________________________________________________
> Gisbert Breitbach, GKSS Forschungszentrum
> Tel.: +49 4152 87 1563
> Fax: +49 4152 87 4 1563
> E-Mail: Gisbert.Breitbach at gkss.de
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
