[Mapbender-users] Query Parameter for a specific external WMS
gisbert.breitbach at gkss.de gisbert.breitbach at gkss.de
Thu Oct 30 10:52:12 EDT 2008
Hi Michael,
I got no Mapbender error log.
I want to use the time parameter for an external WMS server from UK. They
gave me an URL like that:
http://www.npm.ac.uk/rsg/projects/interrisk/ncof_mapserver_wms?map=/var/
www/cgi-bin/wms.map&FORMAT=image%2Fpng&TRANSPARENT=true&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&EXCEPTIONS=XML&LAYERS=zg_MYO_chlor_a_time&SERVICE=MS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A4326&BBOX=-11.25,56.25,0,67.5&WIDTH=256&HEIGHT=256
This URL works for a browser. I removed all other WMS from the GUI. Just
this WMS and demis.nl stay as part of the GUI. I put this WMS on the first
position and removed the setBackground stuff. But the result is no map and
even no frame.
I'm a little bit helpless, Gisbert
____________________________________________________
Gisbert Breitbach, GKSS Forschungszentrum
Tel.: +49 4152 87 1563
Fax: +49 4152 87 4 1563
E-Mail: Gisbert.Breitbach at gkss.de
mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 15:31:45:
> Hi Gisbert,
> your function looks ok. Is your WMS setup to respond accordingly? Did
> you check the mapbender and / or mapserver log?
> If you are using umn: I don't know what mapserver does, when a getmap
> with time parameter request comes in but the requested layer has no
> time metadata setup. I think mapserver tries to create a corresponding
> time expression, but as no time column was defined probably fails.
> Could that be the case?
> Have you looked at that document:
> http://mapserver.gis.umn.edu/docs/howto/wms_time_support ?
> Cheers, Michael
> 2008/10/30  <gisbert.breitbach at gkss.de>:
> > Hi,
> > but how do I add the time parameter as a vendor specific parameter.
> > I tried to use mod_add_vendorspecific.php
> > with that kind of code:
> > <?php
> > # $Id:
> > # add vendor-specific parameters to MapRequest and FeatureInfoRequests
> > # http://www.mapbender.org/index.php/mod_add_vendorspecific.php
> > # Copyright (C) 2002 CCGIS
> > # This program is free software; you can redistribute it and/or modify
> > # it under the terms of the GNU General Public License as published by
> > # the Free Software Foundation; either version 2, or (at your option)
> > # any later version.
> > # This program is distributed in the hope that it will be useful,
> > # but WITHOUT ANY WARRANTY; without even the implied warranty of
> > # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
> > # GNU General Public License for more details.
> > # You should have received a copy of the GNU General Public License
> > # along with this program; if not, write to the Free Software
> > # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
02111-1307,
> > USA.
> > require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
> > mb_registerVendorSpecific("mod_vs_init()");
> > function mod_vs_init(){
> > var re = "time=<?php echo
> > "2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00" ?>";
> >   return re;
> > The only thing that happened is that all maps disappeared including
> > background, overview and mapframe.
> > Best regards,
> > Gisbert
> > mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 14:33:57:
> >> Hi,
> >> I don't think this is possible at the moment. Mapbender is not aware
> >> of the wms time component. What you could do, is to add the time
> >> parameter as a vendor specific parameter, that would be controlled by
> >> a customized module.
> >> If you want to use the wms time parameter you would also have to
setup
> >> your wms accordingly, so that you only have one layer "chlorophyll
> >> measurements" and a time column for your data.
> >> Cheers, Michael
> >> > Hello everybody,
> >> > I'm using Mapbender to show different measured raster maps, for
> > example
> >> > Chlorophyll in the north sea measured by satellites. Every day a
new
> >> > measurement is done. In my own WMS every new measurement means a
new
> > layer
> >> > with a name reflecting the date.
> >> > Other people have solved the problem introducing a time filter
> > parameter
> >> > into the GetMap request like
> >> > ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
> >> > Is it possible to include such a filter parameter into the GetMap
> > request
> >> > of Mapbender and, if yes, how can it be done.
> >> > Many thanks,
> >> > Gisbert Breitbach
> >> > Mapbender_users mailing list
> >> > Mapbender_users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> Michael Schulz
> >> mschulz at webgis.de
> >> in medias res
> >> Gesellschaft für Informationstechnologie mbH
> >> In den Weihermatten 66
> >> 79108 Freiburg
> >> Tel  +49 (0)761 556959-5
> >> Fax +49 (0)761 556959-6
> >> http://www.webgis.de / http://www.zopecms.de
> >> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> >> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> Michael Schulz
> in medias res
> 79108 Freiburg
More information about the Mapbender_users mailing list
