[Mapbender-users] Query Parameter for a specific external WMS
Michael Schulz mschulz at webgis.de
Thu Oct 30 12:26:47 EDT 2008
sorry, but I can't reach the URL, connection timed out ...
Michael
2008/10/30  <gisbert.breitbach at gkss.de>:
> The problem must be elsewhere perhaps in my installation. Even the initial
> add_vendorspecific.php is not working if switched on.
> The URL to the mapbender installation is:
> kofserver2.gkss.de/mapbender
> Temporary a user test with password test is created.
> There are 3 GUIs available
> testmitaddvendor: A test GUI with 2 WMS (demis and the UK stuff), but
> nothing is shown. The mod_add_vendorspecific.php is reset to the initial
> code.
> test: Same GUI with add_vendorspecific switched off
> Interrisk_recent: A real GUI with data in which the UK measurements should
> be included.
> Best regards,
> Gisbert
> ____________________________________________________
> Gisbert Breitbach, GKSS Forschungszentrum
> Tel.: +49 4152 87 1563
> Fax: +49 4152 87 4 1563
> E-Mail: Gisbert.Breitbach at gkss.de
> mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 16:45:09:
>> Hello,
>> is it possible to take a look at your mapbender installation? If it's
>> not possible please separate the maprequests in Firefox (page info ->
>> media) and post them to this list.
>> Maybe they are a little bit enlightening.
>> regards
>> Uli
>> gisbert.breitbach at gkss.de schrieb:
>> > Hi Michael,
>> > I got no Mapbender error log.
>> > I want to use the time parameter for an external WMS server from UK.
> They
>> > gave me an URL like that:
> http://www.npm.ac.uk/rsg/projects/interrisk/ncof_mapserver_wms?map=/var/
>> > www/cgi-bin/wms.map&FORMAT=image%
>> 2Fpng&TRANSPARENT=true&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%
>> 3A59%
>> 3A00&EXCEPTIONS=XML&LAYERS=zg_MYO_chlor_a_time&SERVICE=MS&VERSION=1.
>> 1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A4326&BBOX=-11.25,56.25,0,67.
>> 5&WIDTH=256&HEIGHT=256
>> > This URL works for a browser. I removed all other WMS from the GUI.
> Just
>> > this WMS and demis.nl stay as part of the GUI. I put this WMS on the
> first
>> > position and removed the setBackground stuff. But the result is no map
> and
>> > even no frame.
>> > I'm a little bit helpless, Gisbert
>> > mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 15:31:45:
>> >> Hi Gisbert,
>> >> your function looks ok. Is your WMS setup to respond accordingly? Did
>> >> you check the mapbender and / or mapserver log?
>> >> If you are using umn: I don't know what mapserver does, when a getmap
>> >> with time parameter request comes in but the requested layer has no
>> >> time metadata setup. I think mapserver tries to create a
> corresponding
>> >> time expression, but as no time column was defined probably fails.
>> >> Could that be the case?
>> >> Have you looked at that document:
>> >> http://mapserver.gis.umn.edu/docs/howto/wms_time_support ?
>> >> Cheers, Michael
>> >>> Hi,
>> >>> but how do I add the time parameter as a vendor specific parameter.
>> >>> I tried to use mod_add_vendorspecific.php
>> >>> with that kind of code:
>> >>> <?php
>> >>> # $Id:
>> >>> # add vendor-specific parameters to MapRequest and
> FeatureInfoRequests
>> >>> # http://www.mapbender.org/index.php/mod_add_vendorspecific.php
>> >>> # Copyright (C) 2002 CCGIS
>> >>> # This program is free software; you can redistribute it and/or
> modify
>> >>> # it under the terms of the GNU General Public License as published
> by
>> >>> # the Free Software Foundation; either version 2, or (at your
> option)
>> >>> # any later version.
>> >>> # This program is distributed in the hope that it will be useful,
>> >>> # but WITHOUT ANY WARRANTY; without even the implied warranty of
>> >>> # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
>> >>> # GNU General Public License for more details.
>> >>> # You should have received a copy of the GNU General Public License
>> >>> # along with this program; if not, write to the Free Software
>> >>> # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
>> > 02111-1307,
>> >>> USA.
>> >>> require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
>> >>> mb_registerVendorSpecific("mod_vs_init()");
>> >>> function mod_vs_init(){
>> >>> var re = "time=<?php echo
>> >>> "2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00" ?>";
>> >>>   return re;
>> >>> The only thing that happened is that all maps disappeared including
>> >>> background, overview and mapframe.
>> >>> Best regards,
>> >>> Gisbert
> 14:33:57:
>> >>>> Hi,
>> >>>> I don't think this is possible at the moment. Mapbender is not
> aware
>> >>>> of the wms time component. What you could do, is to add the time
>> >>>> parameter as a vendor specific parameter, that would be controlled
> by
>> >>>> a customized module.
>> >>>> If you want to use the wms time parameter you would also have to
>> > setup
>> >>>> your wms accordingly, so that you only have one layer "chlorophyll
>> >>>> measurements" and a time column for your data.
>> >>>> Cheers, Michael
>> >>>>> Hello everybody,
>> >>>>> I'm using Mapbender to show different measured raster maps, for
>> >>> example
>> >>>>> Chlorophyll in the north sea measured by satellites. Every day a
>> > new
>> >>>>> measurement is done. In my own WMS every new measurement means a
>> > new
>> >>> layer
>> >>>>> with a name reflecting the date.
>> >>>>> Other people have solved the problem introducing a time filter
>> >>> parameter
>> >>>>> into the GetMap request like
>> >>>>> ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
>> >>>>> Is it possible to include such a filter parameter into the GetMap
>> >>> request
>> >>>>> of Mapbender and, if yes, how can it be done.
>> >>>>> Many thanks,
>> >>>>> Gisbert Breitbach
>> >>>>> Mapbender_users mailing list
>> >>>>> Mapbender_users at lists.osgeo.org
>> >>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> >>>> Michael Schulz
>> >>>> in medias res
>> >>>> Gesellschaft für Informationstechnologie mbH
>> >>>> In den Weihermatten 66
>> >>>> 79108 Freiburg
>> >>>> Tel  +49 (0)761 556959-5
>> >>>> Fax +49 (0)761 556959-6
>> >>>> http://www.webgis.de / http://www.zopecms.de
>> >>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> >>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
>> >> Michael Schulz
>> >> in medias res
>> >> 79108 Freiburg
>> Where2B-Konferenz
>> Die Geo-IT Konferenz der WhereGroup
>> vom 9.-10. Dezember 2008 in Bonn
>> Web: www.where2b-conference.com
>> Ulrich Rothstein
>> WhereGroup GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Fon: +49 (0)228 / 90 90 38 - 17
>> Fax: +49 (0)228 / 90 90 38 - 11
>> mailto:uli.rothstein at wheregroup.com
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users mailing list
