AW: AW: [Mapbender-users] MB 2.5: Problems with legends in pdf-print using mapserver's agg
Armin Retterath armin.retterath at lvermgeo.rlp.de
Thu Apr 30 07:03:56 EDT 2009
Hi Herbert,
look at this function in class connector (if you use the curl option in
mapbender):
private function getCURL($url){
		$url=Str_replace(" ","+",$url);
		$url=str_replace(";","%3B",$url);
		$ch = curl_init ($url);
		curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
		curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
		curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
		if(CONNECTION_PROXY != ""){
			curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
		if(CONNECTION_PASSWORD != ""){
			curl_setopt ($ch, CURLOPT_PROXYUSERPWD,
CONNECTION_USER.':'.CONNECTION_PASSWORD);
		curl_setopt ($ch, CURLOPT_RETURNTRANSFER, 1);
		$useragent='GeoPortal Rheinland-Pfalz';
		curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
		$file = curl_exec ($ch);
		curl_close ($ch);
		return $file;
The 3. row defines a replacement for ; - this may be your problem - exchange
this function and test it. (replace the $useragent - if you like ;-))
Greetings
Armin
Am Donnerstag 30 April 2009 08:44:53 schrieb Schönhammer, Herbert:
> Hi Armin,
> I made some tests: Using
>         $output = $this->set("format","image/png; mode=24bit");
> instead of
>         $output = $this->set("format","image/png");
> I get this result:
> - the legend is okay
> - but he mapframe of the print is only white; no error message
> I give up;
> I will switch the background of the legend-module in all gui's to white;
> => the legend-background of mapserver's legend could also be white
> => the print is okay
> => but the appearance of all guis is not okay :-(
> But the better map-quality offered by agg should be a reason for doing that
> Thanks to all, which gave me some hints for troubleshooting.
> regards
> Herbert
> P:S: I will close the "Printtest"-gui in a few days.
> >-----Ursprüngliche Nachricht-----
> >Von: mapbender_users-bounces at lists.osgeo.org
> >[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
> >von Armin Retterath
> >Gesendet: Mittwoch, 29. April 2009 16:13
> >An: Mapbender User List
> >Betreff: Re: AW: [Mapbender-users] MB 2.5: Problems with
> >hello herbert,
> >i think, that mb_log logs only the requests, that are done by
> >the client
> >itself. the printing of the maps is done by getting the
> >pictures with curl or
> >http. there are 2 classes classes/weldMaps2PNG.php and and
> >classes/class_stripRequest.php.
> >in class_stripRequest.php there is a function setPNG()
> >change it for testing.
> >one problem: if you use curl for doing the request you must adopt
> >class_connector.php, cause curl have problems with 'image/png; mode=
> >24bit' in urls - i've got a adopted one if you need it. ;-)
> >greetings
> >armin
> >Am Mittwoch 29 April 2009 14:56:37 schrieb Schönhammer, Herbert:
> >> Hi Michael,
> >> Hi list,
> >> I'm back again with (nearly) the same problem ;-)
> >> Now I've got a server, reachable from Internet. I wanted to
> >build a gui for
> >> testing the troubles. But with some further trial and error I found a
> >> combination of mapserver/agg-parameters and
> >mapbender-parameters which are
> >> avoiding the described problem.
> >> But now I have another problem in printing the map (please
> >see below !)
> >> First things, which are doing right now:
> >> In my MAPFILE I'm using now:
> >> # 24 Bit Farbe
> >> OUTPUTFORMAT
> >>   NAME 'AGGA'
> >>   #MIMETYPE 'image/png'             <======= you MUST NOT
> >use the MIMETYPE
> >> attribute !!!! DRIVER AGG/PNG
> >>   EXTENSION PNG
> >>   IMAGEMODE RGBA
> >> END
> >> LEGEND
> >>   STATUS ON
> >>   KEYSIZE 30 20
> >>   KEYSPACING 10 5
> >>     LABEL
> >>      COLOR 0 0 0
> >>      TYPE TRUETYPE
> >>      FONT "verdana"
> >>      SIZE 8
> >>     END
> >>   TRANSPARENT ON
> >>   IMAGECOLOR 255 255 255
> >> END
> >> In mapbender wms-gui settings I use:
> >> "image/png; mode=24bit" for this wms
> >> The result is
> >> I have a map with good quality ON THE SCREEN, the legend ON
> >THE SCREEN is
> >> okay (has transparent background) AND THE LEGEND ON THE
> >PRINT IS OKAY NOW
> >> (the legend has also a transparent background).
> >> The new problem is:
> >> Now the quality in the MAP of the print is poor. It seems, that the
> >> print-module is ignoring the mapbender-setting "image/png;
> >mode=24bit".
> >> In detail:
> >> In mb_log the following request is logged as request for
> >printing (I have
> >> replaced ' ' through '%20' because the server is online; you
> >may try the
> >> requests !!):
> >http://stadtplan2.regensburg.de/cgi-bin/getows?map=/cityportal-
> >maps/rgb_pri
> >>nttest-agg24.map&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYE
> >RS=strassenach
> >>sen&STYLES=&SRS=EPSG:31468&BBOX=4506700.1038532015,5431380.999
> >99632,4506868.
> >>999796765,5431617.833858754&WIDTH=1780&HEIGHT=2496&FORMAT=imag
> >e/png;%20mode=
> >>24bit&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application
> >/vnd.ogc.se_in
> >>image
> >> The request above delivers the correct image with good
> >quality in 24bit
> >> color.
> >> But in webservers-log all requests for printing DO NOT use
> >the "image/png;
> >> mode=24bit". They only use "image/png". The corresponding line in
> >> apache-log is: 192.168.2.16 - - [29/Apr/2009:14:03:13 +0200] "GET
> >/cgi-bin/getows?map=/cityportal-maps/rgb_printtest-agg24.map&VE
> >RSION=1.1.1&
> >>REQUEST=GetMap&SERVICE=WMS&LAYERS=strassenachsen&STYLES=&SRS=E
> >PSG:31468&BBOX
> >>=4506700.1038532015,5431380.99999632,4506868.999796765,5431617
> >.833858754&WID
> >>TH=1780&HEIGHT=2496&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPAR
> >ENT=TRUE&EXCEP
> >>TIONS=application/vnd.ogc.se_inimage HTTP/1.0" 200 37121 "-" "-"
> >> for trying:
> >maps/rgb_pri
> >RS=strassenach
> >99632,4506868.
> >e/png&BGCOLOR=
> >>0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
> >> The request above delivers poor quality in 8bit color, which
> >is used for
> >> printing !!!
> >> Obviously the logged map-request in mb_log differs from the
> >map-requests
> >> sent to the webserver  !?!?!
> >> Tipps for me ?
> >> Does anybody know where
> >> - the map-requests for printing are created ?
> >> - the map-requests for logging are created ?
> >> - the getlegendgraphic-requests for printing are created ?
> >> How to ensure, that the mapbender settings for mapformat are
> >also used for
> >> printing ?
> >> I'm using MB 2.5 !!
> >> (If you want to make your own trials, this gui is now online
> >for testing:
> >http://stadtplan2.regensburg.de/mb25/frames/login.php?name=stad
> >tplan&passwo
> >>rd=stadtplan&mb_user_myGui=Printtest )
> >> Thanks a lot
> >> greetings
> >> Herbert
> >> >von Michael Schulz
> >> >Gesendet: Dienstag, 3. März 2009 14:05
> >> >Betreff: Re: [Mapbender-users] MB 2.5: Problems with legends
> >> >Hi Herbert,
> >> >I am somewhat at the end of my latin ;-)
> >> >class_SaveLegend should create a white background rectangle in each
> >> >created legend image. If I remember correctly your using
> >the RGBA mode
> >> >in your outputformat. Could you try with only RGB? Maybe
> >the pdf class
> >> >image functions cannot handle alpha channel transparency.
> >> >Cheers, Michael
> >> >2009/3/3 Schönhammer, Herbert <Schoenhammer.Herbert at regensburg.de>:
> >> >> Hi Michael,
> >> >> (sorry today and tomorrow I have a lot of dates :-(, so i'm
> >> >late to answer ! )
> >> >> following your hints, I'm observing following:
> >> >> 1) I'm using again: image/png as wms setting
> >> >> 2) $unlink=false: The png -file of the legend-picture is a
> >> >24 bit picture with the wrong (=black) background-color
> >> >> 3) Looking at apache-log mapbender's
> >> >getlegendgraphic-request uses "image/png"
> >> >> 4) Taking the request from apache-log and sending this
> >> >request to mapserver: the picture comes with transparent
> >> >background (like it should be) as a 24 bit png !
> >> >> => The request from mapbender to mapserver has a correct 24
> >> >bit png as result
> >> >> => The temporary file in the tmp- directory is also a 24bit
> >> >png, but with wrong background color
> >> >> => This wrong (black) png is inc´luded into the generated pdf !
> >> >> P.S: I'm not able to give you access to the services. From
> >> >Internet they will be rechable next weak !
> >> >> regards
> >> >> Herbert
> >> >>>von Michael Schulz
> >> >>>Gesendet: Montag, 2. März 2009 17:57
> >> >>>Hi,
> >> >>>the problem with 24bit rendering is, that mapserver
> >publishes that as
> >> >>>"image/png;mode=24bit" in the wms getcapabilities if you
> >don't define
> >> >>>a special outputformat. So, when you have set image/png as
> >> >>>image-format in mapbender and you get a 24bit png back
> >everything is
> >> >>>perfect.
> >> >>>Have you tried setting $unlink=false in printPDF.conf and
> >> >then examine
> >> >>>the temporary images while generating the pdf output? I
> >am not sure,
> >> >>>if this has impact on the legend images, but it could be
> >worth a try.
> >> >>>Cheers, Michael
> >> >>>2009/3/2 Schönhammer, Herbert
> >> >>>> Hi Michael,
> >> >>>> sorry I don't really understand your hint :-(
> >> >>>> At the moment I use (wms-gui-settings): "image/png"
> >> >>>> But there is no difference between "image/png" and
> >> >>>"image/png; mode=24bit".
> >> >>>> Only the settings in the mapfile determine the outputformat.
> >> >>>So the following always generates a 8bit output. In this case,
> >> >>>the printig of the picture in the legend is okay, but the
> >> >>>quality of the map is very very poor.
> >> >>>> # 8 Bit Farbe
> >> >>>> OUTPUTFORMAT
> >> >>>>    NAME 'AGG_Q'
> >> >>>>    DRIVER AGG/PNG
> >> >>>>    IMAGEMODE RGB
> >> >>>>    FORMATOPTION "QUANTIZE_FORCE=ON"
> >> >>>>    FORMATOPTION "QUANTIZE_DITHER=OFF"
> >> >>>>    FORMATOPTION "QUANTIZE_COLORS=256"
> >> >>>> END
> >> >>>> So I want a map with 24bit color.
> >> >>>> Please: Could you give me some more hints?
> >> >>>> What shall I use ? "image/png" or "image/png; mode=24bit" in
> >> >>>wms-settings?
> >> >>>> What settings in the mapfile should be done in this case ?
> >> >>>> regards
> >> >>>> Herbert Schönhammer
> >> >>>>>von Michael Schulz
> >> >>>>>Gesendet: Montag, 2. März 2009 14:39
> >> >>>>>Hello Mr. Schönhammer,
> >> >>>>>are you using imagemode "image/png;24bit mode" for this
> >service in
> >> >>>>>Mapbender? Then this could be the problem, because
> >> >printPDF sets the
> >> >>>>>imageformat for the maps and the legend icons to image/png.
> >> >>>Then maybe
> >> >>>>>your customized outputformat isn't used anymore... In
> >the GUI the
> >> >>>>>imageformats are used as defined in gui wms settings.
> >> >>>>>Chees, Michael Schulz
> >> >>>>>> Hi list,
> >> >>>>>> I have a new strange problem with pdf-print in Mapbender 2.5.
> >> >>>>>> Lines should be rendered with rounded linejoins. So I'm
> >> >>>>>using mapserver agg
> >> >>>>>> - renderer with an outputformat defined like:
> >> >>>>>> OUTPUTFORMAT
> >> >>>>>>    ##NAME png
> >> >>>>>>    ##DRIVER "GD/PNG"
> >> >>>>>>    MIMETYPE "image/png"
> >> >>>>>>    NAME 'AGGA'
> >> >>>>>>    DRIVER AGG/PNG
> >> >>>>>>    EXTENSION PNG
> >> >>>>>>    IMAGEMODE RGBA
> >> >>>>>>    TRANSPARENT ON
> >> >>>>>> END
> >> >>>>>> Things are done well
> >> >>>>>> in the map
> >> >>>>>> and in the legend of the gui.
> >> >>>>>> Things are going wrong in printing the legend in pdf-print.
> >> >>>>>> The legend picture is drawn with a black background. So the
> >> >>>>>text of the
> >> >>>>>> legend is not readable anymore. (Please see examples in
> >> >>>the appendix)
> >> >>>>>> Until now I used gd-driver. With gd-driver all things are
> >> >>>>>going right.
> >> >>>>>> The background of the legend picture is defined transparent.
> >> >>>>>So the same
> >> >>>>>> legend picture my be used in different guis (with different
> >> >>>>>> background-color) and in pdf-Print.
> >> >>>>>> LEGEND
> >> >>>>>>   STATUS ON
> >> >>>>>>   KEYSIZE 298 398
> >> >>>>>>   KEYSPACING 10 1
> >> >>>>>>   LABEL
> >> >>>>>>     TYPE TRUETYPE
> >> >>>>>>     FONT "verdana"
> >> >>>>>>     SIZE 8
> >> >>>>>>     POSITION lc
> >> >>>>>>   END # END LABEL
> >> >>>>>>   TRANSPARENT ON
> >> >>>>>> END   #LEGEND
> >> >>>>>> I'm not able to detect any difference in the pictures
> >> >>>>>produced by gd or by
> >> >>>>>> agg. In all tools (even photo-editors) the background is
> >> >displayed
> >> >>>>>> transparent. Only in mapbender pdf-print the background is
> >> >>>>>displayed in
> >> >>>>>> black. So I think, the solution could be in pdf-print ?
> >> >>>>>> Has anybody observed similar problems ?
> >> >>>>>> Has anybody a tipp ?
> >> >>>>>> Thanks a lot
> >> >>>>>> Herbert Schönhammer
> >> >>>>>> _______________________________________________
> >> >>>>>> Mapbender_users mailing list
> >> >>>>>> Mapbender_users at lists.osgeo.org
> >> >>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> >>>>>Michael Schulz
> >> >>>>>mschulz at webgis.de
> >> >>>>>in medias res
> >> >>>>>Gesellschaft für Informationstechnologie mbH
> >> >>>>>In den Weihermatten 66
> >> >>>>>79108 Freiburg
> >> >>>>>Tel  +49 (0)761 556959-5
> >> >>>>>Fax +49 (0)761 556959-6
> >> >>>>>http://www.webgis.de / http://www.zopecms.de
> >> >>>>>Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> >> >>>>>Eingetragen im Handelsregister HRB 5930 beim
> >Amtsgericht Freiburg
> >> >>>Michael Schulz
> >> >>>in medias res
> >> >>>79108 Freiburg
> >> >>>Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> >> >Michael Schulz
> >> >in medias res
> >> >79108 Freiburg
> >Im Auftrag
> >Armin Retterath
> >Kompetenz- und Geschäftsstelle Geodateninfrastruktur Rheinland-Pfalz
> >beim
> >Landesamt für Vermessung und Geobasisinformation Rheinland-Pfalz
> >Ferdinand-Sauerbruch-Straße 15
> >56073 Koblenz
> >Telefon 0261/492-466
> >Telefax 0261/492-492
> >http://www.geoportal.rlp.de
Im Auftrag
Armin Retterath
beim
56073 Koblenz
More information about the Mapbender_users mailing list
