[Mapbender-users] Upload WMS fails with no Error
Michael Schulz mschulz at webgis.de
Wed Dec 9 13:31:38 EST 2009
what Mapbender version are you using? It sounds like a http connection
problem. I assume Mapbender is also running on localhost?
Have you configured a proxy? In recent mapbender version you can
define no_proxy locations, when using connection type curl.
Have a look a the logfile. Usually connection problems should show up there.
Cheers, Michael
2009/12/9 Friedrich Hoedl <friedrich.hoedl at hoedl-online.de>:
> Dear Mapbender Community,
> now i have been searching for a long time in this mailinglist to fix my
> phenomenon – but until now I had no success.
> So i´d like to place my question right here in this mailinglist:
> I still have a fully functional mapserver-Installation with a mapfile that
> is based on an example taken out of one of the O´Reilly-Books
> (http://www.webmappingillustrated.com/Beispiele ) and liked to publish a WMS
> with one Layer.
> Therefore I tried to upload this  new WMS to my existing windows mapbender
> Installation.
> I don´t have a problem to load this WMS under Quantum GIS and in there, my
> layer is shown correctly.
> So I went back to mapbender and tried to load the same WMS by clicking “Load
> WMS” in the Main Menue.
> I used the following URL:
> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/global.map&RE
> QUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1
> … and pushed the “Load” - Button.
> After some time (approx. 30 Seconds) the Browser gave back the URL:
> file:
> but nothing else.
> The Logfiles (Apache, PHP and mapbender) doesn´t show anything unusual.
> Does anyone knows what this means?
> I don´t know what´s not ok – the mapfile?
> Something in my mapbender-configuration?
> Opening an external WMS works fine so i´m very confused where to search
> next.
> Thanks for all and best regards
> Fritz Hoedl
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
