[Mapbender-users] map and other GUI elements disappear
Christoph Baudson christoph.baudson at wheregroup.com
Mon Feb 9 03:11:01 EST 2009
Hi Balázs!
Balázs Bámer schrieb:
> Hi All,
> I'm trying to make an experimental Mapbender 2.5.0 GUI. Background WMS
> works fine. I copied all elements to my fresh GUI, switched OFF some.
which elements did you switch off?
I recommend using a debugging tool like Firebug (getfirebug.com) for
Mozilla Firefox. I'm sure you have some JavaScript errors in your
application.
Please report back with these error messages.
If your application is online, please send us a link.
Thanks, Christoph
> This time Mapbender was OK, only some elements (select scale, info
> icon and like) were on wrong place, I mean overlapping other icons,
> etc. I went again to admin2_en page, and began to move the misplaced
> elements. I've changed only Left, Top, Width, Height attributes, not
> the POSITION. However, almost all bigger elements like overview,
> mapframe, digitizing toolbox, menu on the left etc disappeared. In the
> source the iframes are there, but for example for the map iframe, only
> a transparent technical image is included. I can turn on the map and
> the red border of overview (but no overview map) when clicking into
> overview's place. After it, the map is usable, but cannot be
> drag'n'drop resized. Everything else is still missing.
> Mapbender's log contains only stuff like
> 2009.02.06, 08:51:20,Notice: gui id set to guiID: admin2_en
> 2009.02.06, 08:51:20,Notice: mb_validateSession.php: GUI: admin2_en,
> checking file /mapbender/php/mod_showLoggedUser.php...session valid.
> 2009.02.06, 08:51:20,Notice: class_locale: setting locale to en
> 2009.02.06, 08:51:20,Notice: locale en_US.utf8 ok on linux
> 2009.02.06, 08:51:20,Notice: mb_validateSession.php: checking file
> /mapbender/javascripts/map.php
> Apache's log has nothing interesting.
> What did go wrong?
> Thank you in advance.
> Best regards: Balázs Bámer
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
