[Mapbender-users] map and other GUI elements disappear
Christoph Baudson christoph.baudson at wheregroup.com
Mon Feb 9 07:48:48 EST 2009
Hi Balázs,
Balázs Bámer schrieb:
> Hi Christoph,
>> Removing items from tabs is a bit painful at the moment, please apologize
>> the inconvenience.
> It was quite easy: switched off tabs (-: thank you very much! You can check it.
ok...this is the easiest solution ;-)
> How can I find detailed information of all the GUI elements?
A good start is this page
    http://www.mapbender.org/Mapbender_Tutorial_en
Here's a list of application elements
    http://www.mapbender.org/index.php/Category:Modules
If you don't have a wiki account yet, please let me know. You can help
improve the documentation.
> I don't
> know for example what tabs is good for, or how can I switch off the
> selection buttons in the upper right corner. I also have problems whit
> the i (feature info) icon. For the only point and red poligons, it
> doesn't show any info. For the green ones, it comes with an error I
> can't understand (in SQL Developer the same query runs). What can be
> the problem?
Please open a new thread for any new problems that arise.
Posting your problems here is fine, however please bear in mind that
this is not a support line and you might have to be patient before you
will get a reply.
Thanks for using Mapbender,
Christoph
> Firebug still displays some errors. Are they serious? I found some are
> in a try block to make sure the variable has some value.
> Can I disturb you with other questions?
> Thanx again, best regards: Balázs
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
